the previous owner of my 53 C coupe put in a 64 Goldenhawk 259 V/8 auto trans and seats all from the Hawk. It works fine. I'm wondering can I fit a Paxton supercharger onto that engine in the 53 engine bay and not have to cut the hood? seems a shame to cut the hood..also the auto trans seems sluggish on the takeoff. Been talking to Myers about their 700R4 conversion, anybody familiar with that?...Rick Stratton 512-293-0094 or 288-7755
Paxton in 53 coupe?
You can do it using the Avanti style R2/R3 style side mount blower. You'll need to modify the inner fender on the passenger side and move the radiator forward to clear the Avanti water pump housing.
JDP
Arnold Md.
Studebaker On The Net
My Ebay Items
64 GT hawk
63 R2 4 speed GT Hawk (Black)
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
JDP
Arnold Md.
My Ebay Items
64 GT hawk
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
I have one of Meyers adapters in my Stude with a 200-4R which is almost the same as a 700R-4 only lighter duty and smaller physically.
You will have to fabricate a rear crosmember for the transmission and change the driveshaft length etc. Shifter is another problem, I used a floorshift set up, which was the easiest in my case.You will also have to buy and install a convertor lockup wiring setup if you want a lockup convertor and then I bought an adjustable TV cable because the transmission cable adjustment is critical.Check with Bowtie Overdrives website for more info, all this is available from them and others.
Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Frank van Doorn
Omaha, Ne.
I don't know if the 53 hood is lower than a 56 Hawk hood, but I have ran two different supercharger setups on my Hawk. The 57-58 Golden Hawk supercharger setup will fit if the half height motor mounts are used. The Golden Hawk had a hole in the hood, but used the stock height motor mounts. The Avanti side mount will fit if you cut a hole in the fender. I didn't have to move the radiator, but I did remove the fan shroud. The 63-64 Hawk and Lark supercharger mounts lower on the engine so it might fit under the 53 hood.
David
PS. There is no such thing as a 64 Goldenhawk. Also I think 64 Hawks came with 289s. Sorry to nitpick.
David
The 53 hood is way lower in front then the Hawk hood.
JDP
Arnold Md.
My Ebay Items
64 GT hawk
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
JDP
Arnold Md.
My Ebay Items
64 GT hawk
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP Maryland
As to your questions about the 200-4R or the 700R4, figure a minimum of $2,000 to do a quality conversion. (No, I don't want to hear the story about the tranny you got for free and your brother-in-law is a race car fabricator who owed you money.) If you buy the BowTieOverdrives throttle valve linkage kit, a quality performance rebuilt transmission, the adapter, the crossmember, the driveshaft, the shifter; there is no way to do it right for less. Cutting corners on this conversion is guaranteed to make you crazy chasing problems or end up destroying the transmission or both.
My recommendation: go with a 200-4R and get step-by-step advice from someone who has successfully done it.
thnx, jv.
PackardV8PackardV8
thnx, jv.
PackardV8PackardV8
No "Golden Hawk in '64 (it was called a Gran Turismo Hawk...the Golden Hawks were '56-'58)...no 259 in a Hawk in '64. It would have been a full flow 289 (desirable motor).
quote:also the auto trans seems sluggish on the takeoff.
Bellingham, WADick Steinkamp
Bellingham, WA
Bellingham, WA
You have me confused with your "64 Goldenhawk 259." As has been posted, there is no such thing. I do not know if you have a ('56)'57-'58 Golden Hawk engine and supercharger set up, a '64 Gran Turismo Hawk engine and supercharger set up or a 259 engine retrofitted with a supercharger set up. Any of these are possible, but what you list is not possible. Golden Hawks were only made in 1956-1958 and the only Hawk in 1964 was a Gran Turismo Hawk. None of these Hawks used a 259 (except a few export 1964s).
I built a 1953 Commander Starliner with a supercharged 1957 Golden Hawk engine. The engine has to be lowered a small amount for the hood to close completely. This is usually done with lower engine mounts and the solenoid cover. I used a 1955 Studebaker/Borg Warner automatic transmission. Which supercharger mount you use has the biggest effect on whether it will fit under the C/K hood, or not.
Please post your engine number (stamped on the top, left, front of the block) so that we may determine exactly what engine you are starting with.
1959 DeLuxe pickup (restomod)Gary L.
