View Full Version : Window regulator needed.
31Streetrod
04-04-2009, 05:16 PM
Need a good working right front window regulator for a 64 hardtop [J] and/or covertible [L]. P/N 1360888. If no one has one to offer , will have to go with the rebuilt one from SI.
Lost in the 50's
31Streetrod
04-09-2009, 04:21 PM
BUMP
Lost in the 50's
63t-cab
04-09-2009, 04:58 PM
Ron,
I sent you an email,but maybe did'nt go through? I have a 63HT door that I will check on the reg for you. email if you need more info.
Joseph R. Zeiger
31Streetrod
04-09-2009, 05:05 PM
Joe
The 64 is by it's self according to the parts book. The 63 is a different p/n so we can probably assume it won't work.
Ron
Lost in the 50's
studegary
04-10-2009, 01:49 PM
Do you have a regultor at all? Is it just worn? I have had good results fixing worn sectors by building the teeth up with braze and then finish grinding them to the correct shape and keep them lubricated. I have known of driver's door regulators with this fix that have been working for years. If other parts of the regulator are bad, you can usually use parts from different regulators and keep the same mounting frame and arms.
