View Full Version : trade 600 for 500
clonelark
04-02-2009, 04:28 AM
I have a 600cfm Edelbrock carb on my 259 (was on car when i bought it) and it runs well but runs rich, anyone havea 1404 (500cfm) Edelbrock to trade.
Car is available to drive if anyone wants to drive it first. My car is an automatic trans.
http://i40.tinypic.com/o759c1.jpg
DEEPNHOCK
04-02-2009, 07:02 AM
Couple of carb thoughts...
Running 'rich' is not a cfm issue, it is a jetting issue.
Have you re-jetted (primary), changed metering rods/jets (secondary), or metering rod springs (secondary)?
You may well be able to make that carb work just fine without just 'changing it out'.
While there is the issue of 'too much air too soon' off idle hesitation, this carb [u]can</u> be leaned down to get your air/fuel ratio into the range it needs to be in.
They built these carbs to fit a bunch of different applications, and here in Studeworld, we live in a very small neighborhood that basically has only two or three houses on the block.
I would try and find someone with a 'Strip Kit', and spend some time downloading, and reading the Edelbrock tuning manual available for free at:
http://www.edelbrock.com/automotive_new/misc/tech_center/install/carb_faq.shtml
But, if you have already done this, then a donor carb might be a good idea...
HTIH
http://i77.photobucket.com/albums/j54/deepnhock/1937CEBearfootingArtwithLabelgif-1.jpghttp://i77.photobucket.com/albums/j54/deepnhock/SDClogo4forum.jpghttp://i77.photobucket.com/albums/j54/deepnhock/StudebakerTruckFarmerStickerA-1.jpghttp://www.racingstudebakers.com/avatar_01.jpghttp://i77.photobucket.com/albums/j54/deepnhock/GatorDadBigjpg-1-1.jpg
