Okay, besides replacing the bushings on the pedal - what else have you guys done to tighten up the brake pedal linkage and eliminate slop. My brake pedal has ~ 1.25" of movement before it begins to move the rod going into the brake booster.
Are there some other bushings that are redily adaptable to the other wear and contact points that did not use bushings from the factory?
Thomas
Long time hot rodder
Packrat junk collector
'63 Avanti R2 4 speed
Thomas
