Reassemblying heater motor (Brushes)
  • Reassemblying heater motor (Brushes)
    I suppose that the experts have a better way to deal with the problem but the following worked for me.
    A couple of days ago I took my 1950 Champion heater motor apart enough to replace the two wires that extend out of it because the insulation on them was cracking off. While doing this I pulled the end a little too far out and the brushes came out of place. The case is sealed so I needed some way to get to the brushes to hold them in place while I put the motor back together. I drilled two 1/8th inch holes in the end of the case near each of the brushes. I then ran a thread in and around the wire that is attached to each brush and then ran the end of the thread out the same hole and pulled the two ends of the thread until the brush was all the way back in place. I then used tape to hold the two ends of the thread to the outside of the case. I did this for both brushes and then the motor could be put back together. I then took the tape off, took hold of one end of each of the threads and pulled it out of the case. I then sealed the two holes. The motor works fine. Just thought this might help someone sometime since I am always asking for help
    Jimmie
    Orleans, Indiana.
    1950 CHAMPION -ORANGE COUNTY, INDIANA
    sigpicJimmie
    Orange County, Indiana
    Pretty cool- I always appreciate when someone encounters a problem, and thinks it through to a solution. Good work![^]
    Parish, central NY 13131
      Jimmie
      More power to you (pardon the pun) for keeping your heater motor original, but 6v and 12 v replacement motors that fit the heater housing are available from Grainger Supply and others. I can get the Grainger part number for a 6 v motor, but I don't have it handy right now.
      1950 Champion 4 Dr.
      Holdrege NE
      John
      1950 Champion
      W-3 4 Dr. Sedan
      Holdrege NE
        I used a long pair of tweezers to hold the brushes back after oiling the bearings. It is a little tedious, but saved drilling holes.
        duane miller
          I tested the motor when I put it back together and it seems to be alright but it is good to know that I could get the motor new if needed.
          Jimmie
          Orleans Indiana
          quote:Originally posted by Lothar
          Jimmie
          1950 Champion 4 Dr.
          Holdrege NE
          sigpicJimmie
