Will an 1953 Champ overdrive tranny drop in to my 52 Champ? If not what needs to be done.Thanks
Overdrive Compatibility
Should be a direct swap. If you're replacing a worn out unit you have no issues. If you are adding overdrive to one that was a straight 3-speed, you'll also need the lockout cable, wiring harness, kickdown switch and relay.Brad Johnson,
'56 Sky Hawk in process
