View Full Version : question on hawk and commander frame
skip
08-17-2006, 10:13 PM
hi. im trying to find out if the frame for a 64 commander 6 cyl 4 door is the same as a 58 packard hawk. also what would be the frame gauge on the 64?. is it too light because it is a 6 cyl?. thanks for any help. email shiftknob@verizon.net
Alan
08-17-2006, 11:42 PM
No, different WB. Should be 13ga or about .083" Depends on if you live in Michigan or Arazona.
R2Andrea
08-18-2006, 12:31 AM
Those frames are in no way interchangable. The '64 Y body has a 113" wheelbase, the '58K body has a 120.5" wheelbase. All domestic 6 and V8 4 door frames were 11 guage, as were all JT And JTS powered cars. The 6 cyl. 2 door (F body) is the only one to get the 14 guage frame while the V8 2 door (F body) got the 13 guage frame. As far as I can remember, all '53 to '64 K body frames should interchange. The only real difference is that the '57 and earlier frames had a different crossmember to support the 2 piece drive shaft. '58 and newer had the one piece driveshaft.
R2Andy
skip
08-18-2006, 06:29 AM
thank you very much.
skip
08-18-2006, 06:31 AM
thanks very much. skip.
R2Andy
N8N
08-18-2006, 08:53 AM
Also the rear springs changed in 1958 at the same time that the one piece driveshaft was introduced. So any 58-up Hawk frame should work OK. An earlier frame would require that the later spring mounts be transferred over and the center driveshaft support be cut out.
good luck
studegary
08-18-2006, 03:29 PM
good luck
Nate/N8N - How are you going to adjust for the 7.5 inch difference in wheelbase between the two frames that he is asking about?
1959 DeLuxe pickup (restomod)
