I am looking for a 1955 rear end. I live in Prescott, WI. Does anybody know of someone in my area that might have a rear end?
1955 Rear End needed
 Any of the '55-66 Dana 23 rear axle gear sets will work;
 1. Make sure you get the rear axle ratio which matches the one you have now.
 2. If you buy a '55 or later rear axle for the gearset, the brakes are a great improvement, but you'll need the front brakes also.
 thnx, jack vines
 PackardV8PackardV8
 If your car is a 52, the rear ends from 53 up are too wide. Your first post said 55. Which is it? 50 and older Champions used 4 lug wheels so with a 52 you are stuck with a 51 or 52 rear end if you need the whole assembly. I don't know off hand if the 52 rear hubs will fit the earlier rear axles.
 1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
 "I may be lazy, but I'm not shiftless.""In the heart of Arkansas."
 What part of the 52 rear end is bad? The gears from another Dana 23 should fit even if the axles will not. BTW the later brakes will fit your 52 axle housing, even the larger V-8 brakes.
 Let me tell you from experience. 51 or 52 is your only choice. Been there and done that. I ended up with a 1969 Dodge Dart 8 3/4 rearend. My 51 is a V8 3 speed overdrive the Dodge is a 3.94. I believe that's right. CRS
 Middle Tennessee 37th Annual Car Show April 4 2009
 Troy
 Just a thought, but are you sure that the grinding is coming from the rear? You may want to check the front bearings also. While your under there, look for rubbing contact. Something could be shifting and rubbing on the driveline.
 To answer your original query, I have a 54 6-cyl rearend out of my 54K. I'm posting this answer just in case anyone else may want that rearend if it can't help you.
 Bob
 The grinding is for sure coming from the rear, because if you are driving the car you can not hear it. The reason why we caught it was because my Dad happened to be riding in the back seat the last time we went for a ride.
 Unfortunitly according to the last two gentlemen a 54 rear end will not work with our 52. It is amazing how quirky studebakers can be, but I love them all the same.
 You might not need a new rear end, just a wheel bearing. If the gears in the rear end were bad, they'd be noisy in straight-ahead driving, too, unless the problem was solely in the spider gears, which are easily replaced.
 Get a mechanic who is familiar with Studebakers to diagnose the real nature of the problem before throwing parts at it.
 I'd definitely check the wheel bearings before proceeding any farther.
 Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
 I have a Dana 23 from a 56 Flight Hawk You can have if you want to come and get it, just south of St. Louis, Missouri. It does need a front seal but it is a good rear-end.
 Studebaker Fever
 60 Lark
 56 Power Hawk
 Phil Hendrickson
 Arnold, Missouri
 Studebaker Fever
 60 Lark
 56 Power Hawk
 Phil Hendrickson
 Arnold, Missouri
