On the cover that goes over the carb, there is what looks like a rubber plug with two holes in it. Currently, the holes are plugged with bolts. Can anyone tell me what is supposed to be there?
Question about carb cover on 57 GH.
The rubber disk should be mounted to a small piece of spring-steel (2" long x 1/2" wide). It is your "flapper valve". The spring steel bolts to the cover, and the rubber "flapper" goes over the large hole in your housing.
Ray
Ray
www.raylinrestoration.com
Your carburetor has VENTED fuel bowls. Early Carb boxes did NOT have the flapper. Fumes would build-up in the box, and if the car backfired...KABOOM...
The flapper valve lets the fumes escape when not under pressure. As soon as you get a little boost- the flapper closes off the hole.
Ray
Ray
US Patent 2756735 covers the flapper valve. It made hot restarts easier, as fumes from the carb could escape, rather than "flood" the warm engine with too rich a mixture.
Early '57 Golden Hawks,(before PS-2357), used two flapper valves - one on the top surface of the lid, and one directly below in the base. That gave cross ventilation! The valve in the base would have let any fuel from a stuck float or something leak out, too. Later models, with only a valve in the lid, had a small tube with a restricted fitting to do that.
Mike M.
My 57 GH has a 1 inich hole in the bottom of the housing, with no flapper nor any means (bolt holes) of attaching a flapper if there was one available. When I got the car the hole was plugged and it remains so. What am I exposed to in this case.
Ray
Ray
