Carburetor linkage on ‘53
Takes you a while to get to things, huh?
45 years is a long time to remember what goes where[:0]....
Perhaps someone here can take an up close pic of a stock carb setup to show you what it 'should' look like...
Jeff[8D]HTIH (Hope The Info Helps)
I don't have a picture but the set-up is illustrated in the chassis catalog.
There's a spring from the bellcrank to the carb, one from the bellcrank to the rocker cover and one from the carb to the thermostat housing.
If I had the catalog here I could scan it. But I don't.Brad Johnson,
'56 Sky Hawk in process
Sorry day late and a dollar short as always [V]
Any way here you go, the throttle return spring is not the correct spring (coming off carb bellcrank in the picture) but it works
Jon Krimm
1962 Lark Sedan
1961 Champ
