I'm a little stumped.
This is for my 51, but it is a 12V converted car, with alternator, and new battery, so the question is probably just as valid for a newer car.
With car running, everything hooked up, I'm getting about 11.5 volts across the battery terminals at idle (and from alternator terminal to ground), when I rev the engine, no change in voltage. However, when I disconnect the positive terminal of the battery (effectively removing the battery), the car remains running (which indicates to me the alternator is working) and I get about 13V from alternator terminal to ground. When I rev the engine it goes up to about 14.5V.
Hooking the battery terminal back up, again, I get only about 11.5 V across the terminals AND from alternator terminal to ground, again with no change when revving.
I took the alternator to Kragen and they tested it under load and it passed, including the internal voltage regulator. I was almost hoping it would fail, since that would be an easy solution.
WTF? It seems that the alternator is not communicating with the battery, yet the car starts & runs, and BTW, the amp meter acts normal during driving (slightly up when revving, and slight down movement when turning on lights, etc.)
I just recently replaced the battery which was dead and would not maintain charge - now I am thinking the battery may have been OK, and that this new battery is going to drain as I drive and I still haven't figured it out.
Let the electical gurus speak...
Las Vegas, NV - Stop by, coffee's on!
