View Full Version : HELP!! This a "thrust block"? How 2 reinstall it??
sbca96
08-16-2006, 11:44 PM
I have heard that these things called thrust blocks "fall out" when
you pull an axle ... this came out on the end of my old axle ... is
this a thrust block? I was expecting something different.
http://emperorjordan.com/sbca96/images/avantibrakeproject/axle_saga/thrustblock001a.jpg
http://emperorjordan.com/sbca96/images/avantibrakeproject/axle_saga/thrustblock002a.jpg
Tom
JDP
08-17-2006, 12:00 AM
Why yes it is and I know hpw to put it back in too.:)
http://stude.com/sig.jpg
Studebaker On The Net
http://stude.com
Studebaker News Group
Arnold Md.
64 Daytona HT
63 R2 4 speed GT Hawk
63 GT Hawk
63 Avanti R1/AC
63 Avanti R2/4 speed
62 Lark 2 door
62 GT(parts car)
60 Lark convert
60 Hawk
56 Power Hawk/4 speed/289
52 Starliner
51 Commander
sbca96
08-17-2006, 12:20 AM
Oh ... you are a funny guy!!! I have been trying a telescoping deal
with a magnet on the end .... but it keeps sticking to the side when
I get it down there. DO TELL .. how DO you get it back in??????
I sure hope you didnt go to bed yet ...
Tom
JDP
08-17-2006, 12:47 AM
It's only 1 AM.
Here's how I do it. Get a length of gas or brake line tubing and run a wire through the center. Stick the thrust block over the wire sticking out of the line. Put a dab of grease on the block tip and thread it down the axle tube, inserting in the hole. (flashlight helps) Hold it in place with the tubing, pull the wire out, then the tubing.
http://stude.com
Arnold Md.
64 Daytona HT
63 GT Hawk
63 Avanti R1/AC
62 Lark 2 door
62 GT(parts car)
60 Lark convert
60 Hawk
52 Starliner
51 Commander
sbca96
08-17-2006, 02:49 AM
I checked back a couple of times, then went out and continued on the
path I was going. I wasnt able to get it into the hole in the back,
so I took a file and carefully removed the burr around the outside of
the small end - making a slight chamfer. Then I gobbed some axle lube
on the small end, and then stuck it on the telescoping magnet. I fed
it down the axle tube, with a small flashlight inside the tube end. I
got it into the hole, and then stuck a long plastic rod (so it would
not get stuck to the magnet) and pushed it all the way into the hole.
Then I held the plastic against the thrust block, and pulled the end
of the magnet way. This works nicely if you didnt take both axles out
of the rear end (like me). Then I packed the bearing and stuck it all
back together. Thanks for the response though, someone doing a search
will certainly appreciate both our solutions.;)
Tom
prager
08-18-2006, 08:57 AM
Hello all, I pulled both my axles and did not have the thrust block come out as far as I know. Do they always come out? Is it possible that they did and are laying in the axle tube? It is a Dana 44 non posi..Thanks!!
N8N
08-18-2006, 10:27 AM
Only the Twin Traction (limited slip, posi, whatever) axles have the thrust blocks.
prager
08-18-2006, 12:58 PM
Thanks Nate... Is it possible to convert this axle to posi without the thrust blocks, or would that be part of the conversion? Thanks
sbca96
08-18-2006, 03:55 PM
There are a few aftermarket limited slips available for the Dana 44.
Tom
N8N
08-18-2006, 09:01 PM
This is true but be careful, most of them have different spline counts than the Studebaker axles. I don't know what the Stude axles are, but most of the aftermarket ones will have higher spline counts.
IMHO the most cost effective way to put a limited slip under a Stude is just to buy a used Stude axle assembly with a limited slip already in it.
What I would like to know is if one used one of these aftermarket limited slips, and then bought a set of the Moser axles from Fairborn, could you just have the axles made with, say, 35 splines to match the modern limited slip? That would make a really "stealth" yet high strength axle assembly. I keep meaning to ask Phil or Malcolm when I run into them at meets but always end up talking about stuff important to getting my car back together for some reason instead.
Transtar60
08-18-2006, 09:48 PM
Some of the aftermarket Posis meant for pre 72 or 73 Jeeps are available in 19 spline versions for the Dana 44
Allan Songer
03-06-2009, 11:12 PM
I made a tool out of a broomstick with recess in one end for the thrust block--it stays in place with a bit of grease.
Piece of cake.
dynolou2
03-07-2009, 01:05 AM
Nate, sorry but you can't go with later posi section. More splines mean larger diameter axle, also means larger carrier bearings won't fit in the bearing saddles. Randys Ring and Pinion or Mosier should be able to fix you up with a posi carrier siutable for the 19 spline axles. Lou Cote[8D]
