On the control value manual instructions can anyone help me with a couple of explanations: hose & pipe assy., control valve to power cylinder (left turn) 27" and right turn 31.25". What is being measured? Next, "the final adjustment of the reach rod assy., should be made with the steering gear positioned on high center". What is the meaning of high center? Thanks for your help.
Avanti Power Steering
Sounds like the measurements are the hose lengths, and the high center
I belive refers the "tight" spot for the steering box. When I took
mine apart I marked it for easy reassembly.
The following might be helpful.
Avanti power steering system rebuild Q & A
Studebaker Power Steering Pump Rebuild - how to
Studebaker Power Steering Ram Rebuild - how to
Studebaker Power Steering Control Valve - how to
Studebaker Power Steering Hoses Replace - how to
'63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
