We wanted to post the video prior to sharing the whole story of the Lark starting, as it finally starting obviously made our day. First and foremost, we really want to thank everyone here for all your kind words of advice and encouragement. At one point, we really did find ourselves asking whether it really should take representatives from half the nation to get this car started?
Steps that took place prior to Karl starting.
1) Hot wired the coil straight to the battery. Result: nothing.
2) Took apart carb and found float to be stuck. Unstuck float and reassembled. Result: no fountain of fuel, but the car still did not start.
3) Purchased a new battery on the off chance that the one we were using didn't have enough "oomph." Applied some starting fluid for luck. Result: Voila! Karl is alive! (This is the actual footage of it starting and our children screaming in terror...)
Unfortunately, it seems that with our car adventures, every cause has an effect. Yes, Karl started. No, Karl would not shut off. He kept running, loudly and rather well. The smoke did start to decrease a bit. It blew chunks out of the muffler (we'll post pictures of the large rust hole). We would have been happy if that was the worst of it. John fought with the key to get the car to shut off, which engaged the starter, thus ruining the starter (no, we are not posting that footage, although it is all recorded!) After removing the key, a few wires off the switch, and the positive terminal on the battery...Karl was still running like a champ! Finally, John guessed and pulled the coil wire from the top of the distributor cap. Karl went silent once again. We tried to restart, and the starter made a crunchy, winding noise. We stopped for the night.
Moral of the story: we assume that if you hot wire your coil, this will eliminate control over your ignition.
P.S. Anyone have a used starter to sell, or can this one be rebuilt?
John and Tracy Smith
Queen Creek Arizona
[IMG]
