View Full Version : Vacumn tube ??
azopelnut
11-30-2006, 12:25 PM
I recently acquired a 1956 Power Hawk that had been sitting for 25 years. The engine is a 259 but has a four barrel manifold. I have carefully gotten the engine to turn over and have rebuilt the Carter carb but am curious about something.
On the intake maifold between #4 and #6 cylinder there is a T-fitting that I assume is a vacumn port. The fitting is threaded as with most cars but has spring-fitted tube that sits loosely inside the fitting. Where do these two lines connect to and can I replace the spring tube with a threaded tube?
11-30-2006, 01:58 PM
Here's what I think Mike is talking about...
http://static.flickr.com/106/310456008_c673e43e84.jpg
This is a 1960 259 2 bbl, but should be at least similar to yours. A rubber tube goes from the rear connection to the carb throat above the choke butterfly. The choke heat tube slips over the tube that is in the manifold and runs up to the choke housing on the carb.
If this isn't what you are describing, maybe a picture would help.
http://static.flickr.com/100/301465853_2dbe07b7c6_m.jpg
Bellingham, WA
