Ok, my little rescue lark did what all good Studebakers will do, I put a battery in, changed the fuel filter, cleaned the carb, put some fuel down the car and she fired right off.. Settled into a nice smooth idle. There is a knocking noise though. Correct me if I'm wrong, but if a rod bearing is going bad, you pull the plug wire and the offending rod(s) should quiet down a bit. There was no change in the knock. The knocking noise is coming from the front of the engine. Could this be the fiber timing gear? Its making a steady knock and when you accelerate the engine it gets much louder. Any thoughts before I start tearing in?
Thanks,
Bob
(ok Dave, I got it going)
Thanks,
Bob
