View Full Version : Locally Sourced Rear Drum Puller CHEAP
tim87114
12-01-2008, 01:36 PM
Incase you are looking for a drum puller for the tappered axle. Auto Zone carries it under RENTAL TOOL number 27033 "FWD Hub Puller". It is the same as the RWD puller. The price is $25.00 and is listed as thier standard supply for Rental tools. It is for a 3.75" and 4.25" Bolt pattern I believe. The box it came is says 3.75-4.25, so it's an assumption.
http://www.autozone.com/selectedZip,95691/initialAction,accessoryProductDetail/initialR,738632/shopping/selectZip.htm
Yes I bought it. Yes I used it. My drivers side hub popped off with out issues. The passanger side hub was Very, Very rusty. I installed the puller and applied force to the screw. Using a 5 pound sledge hammer gave the screw a couple wacks and it popped right off. Job Done.
FYI, I looked at Checker and NAPA both looking for a "Rear Drum" puller but they did not carry them. I have not gone back to check if they list it as a FWD puller and maybe that is why they didn't even know they had it.
tim87114
12-01-2008, 01:38 PM
Correction, 27037 the slide hammer is 27033. Sorry for the confusion.
Swifster
12-01-2008, 07:21 PM
Back where I come from, that's also known as a steering wheel puller. :D
Tom - Mulberry, FL
1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $2125.60)
http://i74.photobucket.com/albums/i280/Swifster/rollingpi.gif http://i74.photobucket.com/albums/i280/Swifster/The%20Daytona%20File/Avatar%20Size/01-01-05TheStartingPoint.jpg http://i74.photobucket.com/albums/i280/Swifster/The%20Daytona%20File/Avatar%20Size/07-17-07FrontClipRemoved.jpg http://i74.photobucket.com/albums/i280/Swifster/The%20Daytona%20File/Avatar%20Size/04-11-08CoolingFan.jpg
12-01-2008, 07:41 PM
Well I guess if it's built like a steering wheel puller, that will be the last time Tim will be using it without blowing it to bits! [:0]
http://i197.photobucket.com/albums/aa221/studerich/My64Daytona.jpg
studegary
12-01-2008, 08:36 PM
For a Studebaker, you should be looking for a hub puller, not a drum puller.
Tom B
12-01-2008, 08:54 PM
I bought one of these, don't remember what the shipping was, but the puller worked a treat.
http://www.carparts.com/Springfield-Wheel-Puller-Specialty-Automotive-Tools/4199998697-600022196.car
Second one down, not professional, must be the amateur one.
Tom Bredehoft
(Under Construction 564 hrs.)
'05 Legacy Ltd Wagon
All Indiana built cars
Doug M
12-02-2008, 07:09 PM
I rented one from Auto Zone to pull hubs on 51 commander a few years ago,scalded threads one it pulling second hub. Itook it back got another one greesed threads and it worked fine on last hub. Seams a little lite for the job. Doug M
DEEPNHOCK
12-02-2008, 08:17 PM
The true 'cheap' Stude guy would return it to get the 100% deposit back;)
studecruiser
12-04-2008, 01:52 PM
Got my hub puller from Star and Stripes Tool (sastool.com), it was inexpensive and worked great.
http://i118.photobucket.com/albums/o104/studecruiser/StudebakerShine001_001.jpg
