View Full Version : Hawk Door replacement
valleyguy
11-21-2006, 04:20 PM
I'm hoping someone has experienced this problem and knows a fix...
I just replaced the passenger side door on my 58 Hawk, with a
door from another car/year. I've beeen adjusting here and there
to get the gaps even but one unexpected problem is giving me fits. The door fits flush everywhere except at the top, where it sticks out from the body a little, Nothing severe, but definitely not as
flush as it should be.. I did grind some material off the top
hinge hoping that would fix it, but no. Has anyone experienced
this and is there a way to fix it that I'm missing? Thanks,
JDP
11-21-2006, 04:45 PM
I sold a 62 daytona with the same problem from the factory and here's a note from the new owner:
Hi John. Here are the pics of the Stude. He did an amazing job. He is doing some more stuff on it for me too. I just drove down a twin to it that is a piece of ****. We are going to use it as a donor car then part it out. I LOVE the car I bought from you. Show Nate the pics. The fit is unreal.
First the door was in 3/4" at the top, so he realigned it so it fit, then the bottom really stuck out, so he used a 5' long 2x4, drilled a hole about 3 1/2 feet up, bolted another one to that, somehow bolted a 4x4 to the door, then made a triangle and applied leverage in a twisting motion, trying not to break the paint (it didn't break) he kept tweaking until it fit. He said it had to have come from the factory with the lousy fit like that. He then used similar leverage to get the hood to fit. Also, the driver's door was out of alignment and he got it as close as it can get too. It is near perfect now, too. He is awesome!
Pix here:
http://stude.com/align
http://stude.com/sig.jpg
JDP
Arnold Md.
Studebaker On The Net
http://stude.com
My Ebay Items
http://www.stude.com/EBAY/
64 Daytona HT
63 R2 4 speed GT Hawk
63 Avanti R1/AC
63 Lark 2 dr.
62 Lark 2 door
60 Hawk
52 Starlight
52 Starliner
51 Commander
mbstude
11-21-2006, 04:46 PM
Maybe this will help. :)
http://www.ncsdc.com/TechnicalPages/BodyAlign.htm
Matthew Burnette
Hazlehurst, Georgia
'59 Scotsman PU
'63 Daytona HT
http://i81.photobucket.com/albums/j209/mbstude/side_body_avatar.jpg
http://thestudillac.blogspot.com/
KGlowacky
11-21-2006, 05:30 PM
My new NOS doors needed the same adjustment. The body man just start bending the tops until they fit perfectly. Now this was before paint so it was no big deal. Good luck.
bams50
11-21-2006, 09:56 PM
I've used a piece of 4x4 in the past; for example, if the bottom fits but the top doesn't, put a piece of wood on the rocker, close the door against it, then place your hands at the edge of the area that's out and give it a few hard shoves... open remove the wood, check, and repeat as necessary... if you go too far, you can tweak it back till you get it right...
Just takes a little patience, but it's really not that difficult ;)
Parish, central NY 13131
valleyguy
11-22-2006, 09:48 AM
These comments are all very helpful. thanks very much.
the article on panel
alighment provided by MBSTUDE is very helpful since I also have
to get the front fenders aligned after removal as well. I did try the bending method using a block of wood at the door sill but it didn't give, so I guess i didn't aply enough pressure; guess it made me leary of breaking something. I would have taken my car to a body shop but since it is not on the thr road at present, these things are up to me to fix. Everything is in primer so I don't have to worry about messing up the paint. I'll keep at it. Thanks again
KGlowacky
11-22-2006, 04:40 PM
I'm not sure on your model of car. But if you have vent windows take them out first as there (and the windows down) is a chance that you will break them in your adjustment process.
rockne10
11-22-2006, 09:12 PM
Glass is surprisingly flexible and having it up would encourage the top frame to align evenly, as opposed to bowing the center. Placing your fulcrum (2x4) in the vicinity of the hinge, rather than the window would be expedient.
When frame shops bring things back in to alignment, they have to push or pull beyond where they want it so it will spring back to where it should be. An experienced body man will accomplish the task in one minute. A little thought, common sense and experience.
Brad Johnson
33 Rockne 10
51 Commander Starlight
53 Commander Starlight
http://i57.photobucket.com/albums/g233/rockne10/51x2.jpg
valleyguy
11-27-2006, 08:17 AM
ok, as you suggested, I used some leverage at the hinges and
the top now fits flush. With regard to the gaps, I have a 1/4"
gap at the rear edge of the door, (by adjusting the rear
quarter panel) except at the upper edge that fits against the
pillar (see picture) where the gap is much smaller. There is no more adjustment left here
there since the door is as far forward as the hinges will allow.
I think it looks fine but it is correct? All the other gaps around the door are consistent. thanks
http://usera.imagecave.com/jadiggle/Doorgaps002-copy.jpg
bams50
11-27-2006, 06:11 PM
If it concerns you, you could take a 2x4 and place it against the qtr. panel edge where it's narrow, and hit it with a stout hammer; of course, one hit, then check it; repeat as necessary.
It is good to note that gap imperfections are MUCH less noticable once the panels are painted all the same color; so it's up to you to decide how much more you want to monkey with it.
Jeff_H
11-27-2006, 08:14 PM
Can or should I try to twist the driver's door on my '53 hardtop? I've never been satisfied with the fit. I've got the rear qtr pulled out at the bottom as far as I can and 1 shim under the top hinge to get the rear lower corner to almost seal on the rubber. The top front is now a little high compared to the front fender. To top all this I cannot get the rear gap any bigger and its just barely not rubbing the rear qtr. The door is shoved as far forward as it goes as the backing plates for the hinges inside the door are at max. I thought the doors and door opening between the A and B pillar were different since the pass side is good. Measured them and they are within 1/16-1/8 of each other as measured from the A to B post on the body shell inside midway between hinges. A while ago Dick S. posted a pic of my '53 at the Omaha drags and the gaps around the door are visibly not the same front to rear. In order to get it as good as it is I have 2 rubber shims behind the driver side front fender to A post and a "thin" shim on the pass side. That got it so my doors/fenders don't rub on the driver side or are really excessive on the pass side. About the only good news is all the gaps are pretty parallel.
One of my hopeful projects this winter is to try again to fix this....
Jeff in ND
'53 Champion Hardtop
bams50
11-27-2006, 09:34 PM
I'm having a little trouble visualizing your problem, but I'll tell you it is a known practice to lengthen adjustment slots where it's needed- once you're sure that's what you need to get the correct fit...
Any decent body man will tell you that when they assemble a car, or part of one, the fit is frequently better than factory; reason being, of course, that we take more time with one car than a hundred back-to-back on a moving assembly line. This will sometimes mean a LOT of patience required to hang panels to our satisfaction... just remember it's only metal, and it CAN be done!!
valleyguy
11-28-2006, 08:19 AM
thanks BAM50 but I'm a little confused. How can this part be moved by hitting it when it is a fixed part of the body shell?
Like Jeff, I am concerned with the back, upper part of the door
rubbing against the body at this location if the door even sags
slightly. also I didn't know that the adjustment slots can be
altered; I assume this would entail disaemmbling the door? I apologize if these questions seem dumb but I'm new at this... Tks,
bams50
11-28-2006, 03:25 PM
What you're doing is actually bending the metal slightly; the wood prevents hammer marks. Just go carefully, b/c once it's moved it's extremely difficult to bring it back... plus if you bend it too much you can end up with something buckled or bent where you don't want...you don't need to move it much, so a couple taps ought to do it... as I said, hit it once, check the gap, and do it again as needed.
Behind the slots is usually a plate that's threaded for the bolts... usually loosely held in place by a couple tabs so they can move... if you take it apart you can usually remove the plate, elongate the slots in the direction you need with a small grinder bit or drill, and put the plate back in.
Hope this helps; keep asking if you need!
valleyguy
11-28-2006, 03:56 PM
ok, now that makes sense; I'll try the 2x4 method first;
I hate to think about the task of removing the door skin to get at those plates..... Thanks again,
Jeff_H
11-28-2006, 07:10 PM
Last time I had the door off to mess with the fit I felt up inside where the cages hold those plates in and it seemed to me the ends were spot welded down. Couple options come to mind to get them out for surgery.... Somehow drill out some spots and pry up the end of the cage inside the door or maybe cut it out with a cutoff disk on the inside (no room I think). The 3rd option would be to slot the front outside of the door and pull it out that way but then I'd have to fix the sheetmetal there and repaint the inside of the door since that area is visible. Last time I was low on courage thinking about messing up the paint and having to redo. I also think the window guts may need to come out for all this [xx(] I should have spent the time on this stuff before the car was painted, but I didn't think I'd need to go beyond the factory adj range.
Was at my folks place last week for the holiday and if I'd thought of it I should have inspected the original driver door off my car thats in the shed. I don't exactly recall how things are put together in the door for the plates and that door is certainly a good practice part as its rusted badly and has several bad dents and 3 or so bullet holes [:0]
Jeff in ND
