Since I have a free moment I thought I would ask if anyone knows of a vendor that can make a flywheel for an odd application. My Y1 transmission project has ground to a halt because of various reasons...
Stock ohv crank pilot will not accept stock T86/96 pilots and pulling ohv crank for extra machining may get expensive/complicated... I do not want to tear down a good running engine (at this time)
Stock ohv six flywheel is too small (12 vs. 13 inches) but will accept standard Champ truck input shaft and pilot bearing but stock starter drive (uses v8 starter) will not come close enough to start car.
My odd thought is... can some vendor make a V8 sized flywheel with a center hub for the ohv pilot or will some other manufacturer's stock flywheel work so I can bolt a number of parts together to get what I want?
If I have to get a part made it may be easier to eat the cost just to avoid machining a whole lot of other parts.
If I have confused a whole lot of folks, I am truely sorry. I am trying to find the most cost effective way to install a T86 hybred transmission behind an OHV six like a Y1 taxi when most of the original parts no longer exist (unless someone has an 8e ohv truck parts engine on their parts pile)
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
