View Full Version : U JOINT ?? FOR S10 REAREND SWAP
TOMB1
11-19-2006, 09:57 PM
I'm looking for any help on an s10 rearend swap for u-joints? I know they make odd u-joint with different size caps but I dont know if they make the cross different lenghts - the s10 yoke is 1/2" wider than the 1948 land cruiser I have. I just did a tune up and found enough power in the old girl to explode the spider gears and the ring and pinion could stand to see a dentist as well, hence the swap. I seen a post from lstude that gave me which rear end had the right width for the swap, but no yoke advise.... Thanks for any input
Tom Banish
'48 LandCruiser
11-19-2006, 10:05 PM
Driveline shops and maybe some parts stores sell a special "U" joint that some Chevys use, that has the '64 Chev. 1/2 ton truck Spicer joint on two ends (same as Stude) and a larger one on the other 2 ends, maybe that would convert it.
Studebakers Northwest
Ferndale, WA
TOMB1
11-19-2006, 10:26 PM
Thank you STUDERICH - I knew they made one but I didn't know for what application.
Tom Banish
'48 LandCruiser
