View Full Version : new truck numbers and model
kpcoupe
10-19-2008, 06:50 PM
can someone tell me what these numbers mean there are from the inside of the drivers door
serial E5-135298
model 7E5 - 112
does this mean it is a 5e7 i am not sure though cause it has a six and rock auto only shows the 5e7's with v8's
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
10-19-2008, 06:58 PM
also i guess i should ad the reason i was asking is because it has a holley carb on the 6 and i know that it not correct and i can not get it to idle low enough the motor sounds good when it is at about 1500 rpm's but below that it just stalls. i have been through the carb three times just to make sure that all the pasages were clean and they are. but when i adjust the idle screw on the base plate there is no difference. i think it is because it is half blocked by the intake. and i am not sure if this carb is even going to work for this truck so i think i may try and locate a original carb.
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
Guido
10-19-2008, 07:13 PM
Kevin,
This is usually Frank Drumheller's (studelark) territory. Below is a breakdown:
E - Truck series produced between the 1955 - 1964 model years
5 - 1/2 ton model with the Champion engine
7E - 1962 model year
135298 - Serial number
112 - The wheelbase (112")
A 5E7 would be a V-8 truck from 1960 as "7" designated a V-8 1/2 ton truck.
http://thumb14.webshots.net/t/63/663/9/36/86/2567936860097493054TXiheL_th.jpgGuido Salvage - "Where rust is beautiful" and real Studebaker horsepower lives
Guido
Kevin,
kpcoupe
10-19-2008, 07:29 PM
ok that makes more since. my titlt says 60 but it is also an abandoned title but the serial number is correct. i guess i could try to get the dmv to fix it when i get it in my name. but that for sure means it is a 62 model?
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
10-19-2008, 07:30 PM
also does anyone know what the original carb should be?
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
Guido
10-19-2008, 07:57 PM
7E is a 1962 model. I do not have my books handy and my only OHV 6 is 30 miles from here, but I think a Carter RBS. I think they show up often on e-Bay.
Mark57
10-21-2008, 11:20 PM
According to the Shop Manual, the original carb on a 7E series with a 170 OHV engine is a Carter AS-3370-S. The RBS is listed as the standard on an 8E truck.
<h5>Mark
'57 Transtar Deluxe
Vancouver Island
Are you planning to attend the NW Overdrive Tour in Parksville, BC
May 23 & 24, 2009?</h5>
http://i186.photobucket.com/albums/x153/MarkH57/CandyStoreThumb.jpg
52-fan
10-22-2008, 11:00 AM
Kevin, I just saw your post. Does this mean you have a Studebaker pickup now?
http://i152.photobucket.com/albums/s186/52-fan/StudebakersofArkansas2-1.jpg
1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
kpcoupe
10-22-2008, 09:52 PM
yes i have one now. i finished the front brakes to night and started to take the rears off and the puller i got from oriellys isnt big enough so i will have to try and find a bigger one. i did try and call you the other day, i had a carb question i thought you could help me with. so if you see this give me a call.
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
kpcoupe
10-22-2008, 09:54 PM
also would any one have a carter AS 3370-S they would like to get rid of cheap?
Kevin Phillips
Jacksonville,AR
57 Silver Hawk
52-fan
10-23-2008, 09:36 AM
Kevin,
I've got the puller you need and we may have a carb around here also. I'll call you this evening if I don't forget. BTW If you call the house leave a message. We don't usually answer before the machine picks up.
