I have a 52 small six that needs rebuilding and have just been told of a 53 larger 6 with a rebuilt, that is about to be pulled for a race engine. Will the motor mounts and transmission line up or should I stick with the smaller six? Thank you.
1952-1953 Engine differences
What year/model/body style are you considering putting the engine in?
Paul
Winston-Salem, NC
Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.comPaul
Winston-Salem, NC
Are you sure it has the wider heads than your Champion, and also the Exhaust Manifolds are a dead giveaway that it is really a Commander "245" Big 6, the runners to the block hump up at the front and rear of the block and are square where Champions are level and round.
It would be more likely a OHV "170" 6, than a Commander Big 6 flathead, as it would be a bit of a trick to install.
Studebakers Northwest
Ferndale, WAStudeRich
quote:Never seen a Big Six in any car newer than a '50 Commander. But I'm sure it could be done.
Matthew, the nomenclature police are on your trail. What's the difference between a Big Six and a Commander Six?
But, to the current point,
The '53 six was no larger than the '52. The '55 six was larger displacement (185cid) and may, in fact, be something that could have been swapped in to your donor; perfect fit.
The Commander six was too long to fit in to any '52 unless the firewall was cut and all drivetrain altered.Brad Johnson,
'56 Sky Hawk in process
