I have a 259 full flow engine that was bored and hot tanked.
I also had the shop replace the freeze plugs.
After I rebuilt and installed the engine I developed a pretty series oil leak.
It appeared to come from the torque converter at first then the rear main.
I pulled the engine removed the transmission and bell housing and torque converter.
When I started to remove the flex plate, I noticed and empty bolt hole roughly about an inch below the distributor in the back of the engine. I never replaced these and was not checking it when I assembled the engine.
I will reassemble the engine and test it on a test stand.
In the meantime has anyone had similar experience and/or do you think this missing plug is a cause of such oil leak?
Thanks
Paul
Thanks
Paul
