I got back from Hershey with this surge of positive energy. I went to the hawk and started to fix everything I thought was wrong. These trips to auto events tend to give me hope for my project. I have been having such a problem with the lights I thought I would replace the fuse box and work from there, well I got everything rewired and I tried the brake lights and "No change" however now the signal lights worked correct and no intermittingly like before. I wondered what if I do something different, I pulled on the tun signal arm and than pressed the brake Both lights came on[]oh boy, I put the signal light on and pressed the brake and it worked, both sides. My question is what would make it no work beforedoes the arm ground aganst something? I took a small screw driver and pry it away from the housing gently and now everthing works as it should[8D]
Studebakers forever!
