My relatively low mileage '58 289 is being rebuilt, mostly because of a head gasket leak after long storage. I'm using an upgraded (R1+) cam and valve springs, cupped pistons with a bit higher compression. I was planning to use Phil's stainless valves.
The shop manager says that my original valves will be "just fine" with a bit of "cleaning up".
Does that seem like sound advice? Or is it short-sighted to save a couple of hundred dollars on valves in the middle of a several thousand dollar rebuild?
