View Full Version : chev engine mounts
DaveH
11-15-2006, 08:40 AM
Does anybody know who sells engine mounts to convert 49 1/2 ton 6cyl to v/8 chev w/auto with stock front end.
11-15-2006, 09:49 AM
Nobody sells mounts to specifically make this conversion. You can buy universal type mounts that you will have to modify to fit the frame from people like http://www.chassisengineeringinc.com/
Keep in mind that positioning the engine and trans in the frame and fabricating the mounts is probably the easiest part of a swap. There are more failed swaps (and failed restorations) out there than completed ones. Get some help if you haven't done a couple before, plan it out carefully, develop a budget...before you start cutting.
http://static.flickr.com/100/292046667_cc1661ba0e_m.jpg
studegary
11-15-2006, 08:11 PM
I don't think anyone makes those mounts and I do not believe that it would be simple, but could be done. I think that the better way is to put a GM sub frame under the front end of the truck. This way you get the corect engine cradle along with a better ride, disc brakes and power steering. I have owned a couple of Studebaker pickups converted in this manner.
1959 DeLuxe pickup (restomod)
studegary
