My problem is timing on my r2 with the mopar conversion in a prestolite dis.I tried to search but can't find this problem. I set the timing with the vacum adv. disconnected to 24 degrees @ 1600 rpm tighten the dis and let it idle it reads about 4 degree atdc .hessiates hicups and is slow to rev.If I bring it up to 2200 the timing mark is almost out of sight on top I and guessing at about 32 degrees bftdc. Called dave t-bo ,It's one of his dis ,he tells me to set it @8 degrees at 650rpm ,but when I bring it up to 2200rpm the mark goes out of sight over the top the vib damper, And I still have hesitation from idle to rev. So I advance it to 14 degrees btdc at 650 lockit down ,rev to 2200rpm the mark goes out of sight but no heitation and runs like a raped ape,but I am afraid to leave it there (at this setting there is no ping or detination that I can feel or hear). Also after setting the dis I connect the vacum line and there isn't anychange in the mark at idle at any of the settings.I checked vacum bleed down on the vacum advance and the points plate moves and the diafram holds vacum.At this setting of 14 degrees is what the car turn a 15.2 at the drags, my concern is I have to drive 400 miles to be in a wedding next week,and am trying to find out if I can drive a distance @2500 rpm and not hurt anything.
Thanks
JOE
1959 HARDTOP R2 clone
1960 conv
SDC member since 1972
Thanks
JOE
1960 conv
