I rebuilt my '52 Champion's Carter WE-715s carb last week & I noticed when the car is run in hot weather, then shut off, the gas will purge out of a tiny vent hole in the main carb body.Not a lot of gas, but enough to run down the outside,to the base of the carb. This will stop after a few minutes.The tiny hole is located on the drivers side of the carb,horizontal in the main carb body mounting flange, just above the throttle body. It is seen just left of the screw that holds the main carb onto the lower throttle body.
I was very careful to set the choke level to 7/16" with the bowl cover upside down,as suggested elsewhere in this forum. This setting is 1/16" greater than the shop manual calls for, which should bring my fuel level lower than stock.
Has anyone else had the gas percolate out of this hole after a hot shutdown? Should I lower the fuel level any further to stop the weeping?
I was very careful to soak all parts of the carb & blow out all passages. I was also careful to replace the 2 check balls.
Any suggestions would be greatly appreciated!
Steve
'52 Champion 170 Sedan
Steve
