I called NAPA this morning to cross reference some front wheel brg seal numbers I got off the 56J website for my 56 Golden Hawk. They had them in stock. I decided to take the '53 (coupe from Cuba) and run uptown and get them.
When I hit the starter I could see flames in the engine compartment through the seal around the steering column.
I put the car in neutral, jumped out and was able to push it out of the garage.
I then popped the hood and found that two wires had rubbed through the fabric insulation and were burning.
I couldn't get the battery cable off but was able to separate the two wires and get the fire put out before any significant damage was done.
I then ran and got a wrench and loosened the battery cable but still could not get it off. Had to use a puller.
I had the wires replaced in less than an hour, took it for a test run and all seems to be OK now.
But, you can bet I'll be disconnecting the cable from now on until I get a new harness.
Any suggestions on where to get a good quality harness?
I think I'll also insatll one of those disconnect knobs.
fstst56
fstst56
