1958 President 2 door hard top. tank is very clean, is venting well, but after using 8 gallons I run out of gas. I blew air from the front of the car back into the tank thinking maybe something could be blocking the line, still run out of gas. could the line have a hole in it at the level where 8 gallons is used? do these lines rust if the car sat for a few years without a full tank? if so is there a way to repair just the line without removing the tank. could I cut a small hole in the line using a hack saw through the float hole to cause the line to draw from a lower spot in the tank? can the line be removed and repaired without taking the tank out? the line is soldered in at the bottom front of the tank. any suggestions??? thanks in advance. Jim R
Jim Rostron
Jim Rostron
