I have been looking at some web sights and am wondering what units people have used when adding air to a 62 Hawk. I would like to get a unit that is both heat and air along with defrost. Plan on positioning the vents in different locations, two in the center and one on each end of the dash. Any information and pics would be great.
adding airconditioning to 62 hawk
Vintage Air. Buy it. Do it. End of discussion! BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
What you are asking for would be pure custom. You can try vintage air (http://www.vintageair.com) and see if you can piece something together. The easiest route is to add just the AC to the car and leave the stock heating/defrost alone, vintage air has bracket kits and they can put together the evaporator, compressor etc. for you as well. There have been several post by myself and others over the last week or so on the install of the compressor and brackets etc. Note that if you go with the Vintage Air setup you need to let them know if you have power steering or not, two different idler pulley setups. Good luck.
Dan White
64 R1 GT
64 R2 GTDan White
64 R1 GT
64 R2 GT
58 C Cab
57 Broadmoor (Marvin)
Hey in Dallas,
Have you heard of the other Texas-based aftermarket vintage A/C company, down in Selma (northeast of San Antonio)? It's Hot Rod Air, and I checked out their website when considering my options. I'm inclined to contact them when I get serious about A/C for my truck, as I suspect they will be more likely than Vintage Air to let me "drop in on them" with my truck so they can get ideas of what will work. Here's their website: HotRodAir.com
{ADDED LATER}: Now that I have read the experiences of OldGuy829 (below) with Vintage Air, I'm pretty enthused that I can talk with them about what I need, as well. Esp. if the owner of the company loves Studebakers! Which reminds me - Yes, I should ask Ebon first about all this A/C stuff when the time comes.
[img=left]http://simps.us/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
The Red-Headed Amazon
Deep in the heart of Texas
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
Although I am in Dallas the car is located in St. Louis so will have the work done in that area. Will also check out Hot Rod Air and see what they have. The sights I have seen so far all seem to have the same product.
Just have Ebon Jones ("railway" here) down in Harlingen do it for you. He is an expert AC guy and has done many many Studes. Don't reinvent the wheel! [^]
Bellingham, WA
I'm in San Antonio and use Vintage Air. Couple of comments... you can drop in on Vintage Air anytime. First time I did AC I was nervous. So I drove it out there before hooking up the electrical. They did a quick confirmation I had everything right. Great service. Over the years I have learned that most companies copy VA's stuff, however, VA actually brings in the cars and installs the units during their R&D process. The Sanden compressor they use, and several other components (like the door operations on the evaporator) came about because of their research and demand for excellence. I believe their newest unit has separated the AC and Heat function from crossflow. I haven't studied up on it yet. [The owner, Jack Chisenhall, has a 53 Stude that ran over 200 MPH at Bonnevilee, with the air on]. I'm pretty much a CASO, but I'll always use Vintage Air. For the few bucks difference, it's worth it for the quality, warranty, reputation, service these guys give.
I'm probably prejudiced. On their website is a section on customers cars. My 41 Pontiac is there with a pic of the dash install. It would have been an under dash add on deal, but their tech section explained that it works better the higher up you get it, and encouraged me to play with a dash install. Swapped out various outlets with me until I came up with that setup.
NO, I don't work there and I'm not related. Just really stoked about the company.
San antonio TX. 53 Champion Coupe, to be brought back from the dead.
"Of course it will fit, I have a torch"
