View Full Version : Fuel gage sending unit gasket
259man
11-10-2006, 01:01 PM
Hello, everyone.
Due to a leak, I need to replace the gasket at the gage sending unit on the fuel tank of my '62 Lark Cruiser.
Should I use any sort of gasket sealant or adhesive when installing the new gasket?
Thanks!
Tom
60Lark
11-10-2006, 01:27 PM
259 - NO SEALANT OR ADHESIVE IS NECESSARY, JUST MAKE SURE THE GASKET SURFACE IS CLEAN
http://im1.shutterfly.com/procserv/47b6ce23b3127cce8d0f1fc7bd4900000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
kmul221
11-10-2006, 01:56 PM
I made one out of the sheets of cork from a auto or industrial supply
No adhesive was used ,it was in the car 9yrs.with no problems & as far as I know still is.
Be sure to disconnect the battery when working in that area to prevent possibility of sparks or KA-BOOM !
r1lark
11-11-2006, 12:05 PM
Same stuff I use, except mine has the 3M adhesive on one side. Cut out the gasket, punch the holes, and then peel off the paper and stick the gasket on the sending unit. Then you don't have to worry about lining the gasket up and keeping it lined up while you put the first couple of screws in.
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
259man
11-14-2006, 03:16 PM
Thanks for the advice, everyone.
It'll be nice to fill up the tank without leaking fuel and stinking up the barn in the process!
Thanks again.
Tom
