my 66 commander rear wheel bearings need replacing. How do you pull them? I removed the 4 nuts that hold the retainer on does it take a puller to remove the axles? PS it has flanged axles. Doug M
HELP removing rear axles 66 commander
The bearings are a snug fit to the axle housing, unlike a press fit onto the axles themselves. I use what is known as a "Morgan Knokker" as it is an approx 4 lb weight slide hammer & doesnt take much effort to pop the axles out on a flanged axle setup. I've never tried another way, but if you bolted a flat plate on the inside of the axle housing, you might be able to pop the axles out by prying against the plate with a long screwdriver or similar long steel rod against the inner flange of the axle.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
'Shouldn't have to use heat, Doug, so don't! BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
