I changed wheels and tires on my '54 Starliner recently, and wanted to share my experience with this for those who might be thinking of doing the same thing.
When I put the car on the road 11 years ago after a hiatus of many years, I bought P205 70R 15 tires and used them on the stock '54 wheels. They fit and worked fine. No problems.
Due to age, I thought it would be a good idea to replace these tires now, even though they have only about 3,000 miles on them. I thought that I might as well also switch to rear wheel drive model Chrysler wheels at the same time, as has been suggested in TW and elsewhere, for safety reasons.
I bought new P205 70R 15s and had them installed on the Chrysler wheels, and then put them onto the Studebaker. I was surprised to find that the rear wheels are now only about 1 1/2 or 2 inches away from the rear fender at the top of the wheel opening. They stick out so far that they don't really look right.
I took the car for a long drive under many road conditions and find no rubbing interference anywhere at all, so I guess it's okay in that respect. But I'm disappointed in the appearance of this setup, at least on the rear of the car. The front ones look okay.
So I want to warn others that although this setup has been recommended, you may not be thrilled with the end result!
The only positive thing I see is that using these wheels has seemed to stop the wheelcovers from creeping around the rim.
I would be interested in hearing your experiences in regard to using the Chrysler wheels on the early C and K bodies.
Dave Bonn
'54 Champion Starliner
Dave Bonn
