I have a '49 Commander with an overheating problem. At an idle the engine will continue to heat and the gauge goes up.
It has a newly cleaned radiator, new hoses, the water pump is old but pumping, it has an anti-freeze water mixture, steel bladed fan.
A list of possibles for any engine: over bored, plugged some where, bad radiator, water pump bad, belt gone, timing, flex fan, collapsed hose.
What can you add to the above list that I can check ?
BRAD
BRAD
