View Full Version : 1960 champ truck and lark fan shroud, the same?
supersonictoys
08-13-2008, 11:29 AM
I have a 60 champ truck with a flat head 6 and a 3 speed non overdrive and it didnt come with a fan shroud. the fan is several inches from the radiator and when I run it on the freeway the fan just doesnt quite get the job done as the temp gauge just slowly keeps creeping up till it goes past 3/4. I am wondering if the shroud from a much more common lark would bolt on and fit and if anyone out there might have one they would part with?? would be glad to pay for it and shipping. please let me know. thanks. ;)
supersonictoys
08-14-2008, 01:21 AM
guess no one knows .....
Alan
08-14-2008, 02:23 AM
Sup, I have never seen a Champ truck with a shroud. I have a 63 T-cab and that did not come with a shroud. But with the radiator in it I have had no problems. You can always make yourself up one if you think you really need it.
ChampTrucking
08-14-2008, 07:53 AM
Hey Super,Dave T-bow makes a repo fan shroud for Lark types.He might be able to answer your question AND sell you the part.
sirbum
08-14-2008, 10:16 AM
I acquired two champ trucks to build one truck. Neither truck came with shroud.
52-fan
08-14-2008, 11:28 AM
I have never compared a Lark side by side to a T cab truck, but I believe that the trucks used different radiators and the T cab is mounted higher on the frame compared to the Lark. My guess would be that a shroud for the truck would be different. Of course, it might be possible to adapt one if you had it available and didn't mind working it over.
http://i152.photobucket.com/albums/s186/52-fan/StudebakersofArkansas2-1.jpg
1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
41 Frank
08-14-2008, 01:24 PM
If your overheating problem only occurs at freeway speeds it is most likely not related to the lack of a shroud. At freeway speeds most vehicles don't require a fan to stay cool. I would look for a restricted radiator core not letting the coolant circulate fast enough at higher speeds first, also check the heat riser operation and thermostat.
Frank van Doorn
1962 GT Hawk 4 speed
1963 Daytona Conv
1941 Champion R-2 Rod
08-14-2008, 02:47 PM
If you are driving a 170 or 245 Six, more than 50-55 MPH with 4.09 gears and no Overdrive, that is 90% of your problem!
If so, you would be exceeding it's "comfort zone", a steady cruise RPM of 2400-2800 RPM!
Studebakers Northwest
Ferndale, WA
Transtar60
08-14-2008, 03:28 PM
There is no fan shroud listed for the Champ truck in either 57-61 or 62-64 parts books.
I have yet to see one in a Lark!
http://racingstudebakers.com/coppermine/albums/userpics/10056/5E13%20Pic%203.JPG
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
59 Lark
etc
08-14-2008, 03:54 PM
The fan shroud was a very rarely ordered option usually on Air Conditioned later Larks, and I remember seeing the one of about three I have ever seen, in the pic's of the '63 2Dr. Lark Marshall that JDP sold on ebay with several H.D. options and standard items... How about that! ... I've got it! [^]
http://i197.photobucket.com/albums/aa221/studerich/63V-F3PoliceCar4.jpg
http://i197.photobucket.com/albums/aa221/studerich/63V-F3PoliceCar8.jpg
I think this car is a 289 Auto. 2V. W/P/S, and Pwr. Drum Brakes, W/S Washer, & Tinted W/S only.
Amazing isn't it what that Northeastern SALT can do! My guess is the whole body and frame under that nice paint is GONE!
I think it would be a good idea, if there is a whole lot of non-shroud discussion about this car or otherwise to take it to a new post, however, rather than sabatauge Super's post! :)
blackhawk
08-15-2008, 04:14 AM
I have a shroud for a late Lark hanging on the wall of my garage. I originally bought it for my '63 Wagonaire when I tried to convert it to AC. I also have a '63 Champ pickup. So, tomorrow evening I can take some measurements to see if the shroud will fit the Champ. I haven't used my pickup in a long time so I can't remember whether the radiator is different. By the way, the temp gauges on all my Studebakers read more than 3/4 when hot because I have always used 195-degree thermostats. So, I don't consider this a problem unless you are running a cooler thermostat and want the temperature that low. Regardless, if it is overheating I'd look for other causes since these trucks did not come with fan shrouds as far as I know and should not need one to keep the engine from overheating. Maybe the cooling passages in the engine block are full of crud. Another thought - maybe the fan IS further away from the radiator than it should be. I can't remember if there were different spacers for different applications. Maybe a previous owner set it up wrong. I will see how close the fan is to the radiator on my Champ, although it is a V8 model and not a six. ~Dale
http://i202.photobucket.com/albums/aa67/DHaggster/Studebaker%20fan%20shroud/IMG_2773.jpgFront side
http://i202.photobucket.com/albums/aa67/DHaggster/Studebaker%20fan%20shroud/IMG_2779.jpg Rear side
http://i202.photobucket.com/albums/aa67/DHaggster/Studebaker%20fan%20shroud/IMG_2776.jpg PN 1550705
My '61 Champ pickup has radiator PN 1554339. This PN is listed in the truck part manual. It is also listed in the car chassis part manual for '62 and '63 Lark. So, I assume that the fan shroud will fit the Champ as well as the Lark, which seems no surprise since the front end sheet metal of the Champ is the same as the 59-60 Lark. I measured the distance of the fan from the radiator. It is 2-1/4 inches at its closest point, the bottom of the arc described by the moving fan blades.
~Dale
Warren Webb
08-16-2008, 01:57 PM
A cheap fix could be a spacer for the fan to bring it closer to the radiator. My Champ & 60 Lark both run at 3/4 on the temp guage. Checking the accuracy of the guage would be the first step.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
