OK, I have been led astray bu another interchange list, the kit I talked about is close, but no cigar. The some of the internals of the valve are different on the kit, although the outside is the same. I'll do some more research and get back to you.
Ignore the below:
I found that the 64-70 Ford control valve is a clone of the Bendix unit and found a kit at my FLAPS. It's a Gates 351070 and the good news is it's as cheap as just the two seals from the vendors and more complete and with better instructions. It will rebuild the entire valve if needed and even has a end cap gasket that Studebaker omitted.
BTW, the whole valve is often on ebay under the Ford listing.
JDP/Maryland
"I'm a great believer in luck and I find the harder I work, the more I have of it."
Thomas Jefferson
Ignore the below:
JDP/Maryland
Thomas Jefferson
