That @#$% transmission spacer...
  • That @#$% transmission spacer...
    OK, after realizing that the transmission spacer was installed on the wrong side of the car (passenger's side instead of driver's), I went out today and jacked up the trans pan, loosened the x-member bolts, and managed to wiggle the spacer out off of the passenger's side transmission mount stud.
    But there was no way, no matter how much I tried, that I could gain enough space to insert the spacer on the driver's side (which, as StudeRich noted, has a stud 1/2" longer just for this purpose).
    So here's my question: is there any harm in just bolting up everything nice and snug without the spacer and driving it to the trans shop to have them drop the x-member and install the @#$% spacer? [:I] What will happen if I drive without it?
    I feel I'm really close to getting the car rolling, and I think I'm ill-equipped to handle this particular bit of minutiae myself...
    ...Unless y'all have some suggestions on how to do it without me busting my cuss-bone! [}]
    Clark in San Diego
    '63 F2/Lark Standard
    The Official Website of the San Diego Chapter of the Studebaker Drivers Club. Serving San Diego County
    Git under the car, take the weight off the cross memeber with a jack and jack stand or cribbing, (push up on the transmission) unbolt the left side thru-the-crossmemeber nut and the two screws holding the mount to the bellhousing. Disassemble the mounting unit,(take it off the car) put the spacer in and return the two bolts to the BH. Return the nut and washers to the stud. There may be some additional jacking involved to get the assembly back together.
    This should save you a trip to the shop.
    Tom Bredehoft
    '53 Commander Coupe
    (Under Construction 379 hrs.)
    '05 Legacy Ltd Wagon
    All Indiana built cars
      Can't you just stick some body shims (open on one side) stacked to the right height and call it a day?
      ErnieR
        I remember reading here not long ago about someone welding up a bunch of washers to the right thickness and cutting a notch to slide them in. I suppose I could fire up the Dremel and cut a slice out of one of the Stude washers and accomplish the same thing. It's not going to go anywhere, right?
        Clark in San Diego
          I'll be watching any responses to Clark's question. After a little cleaning in this area of the underside of our Hawk, replacing the transmission mounts is the next step.
          Perry
          '23 Special Six,
          '50 Business Champ,
          '50 Starlight Champ,
          '60 Lark droptop,
          '63 GT R1
          Perry
          \'50 Business Champion
          \'50 Starlight Champion
          \'60 Lark Convertible,
          \'63 GT R1,
          \'67 Triumph TR4A
            Clark, I think your idea would work fine.
            1957 President two door
              Heres my post from June 29
              A couple weeks ago, I made a stack of washers the right thickness and sawed a slot in the stack. I welded all but one together. I turned the top one 90 degrees and drilled and tapped a hole in the stack and put a clearance hole in the top washer. I jacked up the transmission (see my old post) and with the stud still through the cross member, slid the stack in with the one loose washer on the bottom, and put the screw in to hold the bottom one in place and keep the stack from falling out. Then I let the transmission down and put on the washer, lock washer and nut.
              Bill
              http://www.rustyrestorations.org/index.php
                I agree with Tom B. It would take about the same amount of time to support the trans and remove the mount to install the spacer. Verses welding and cutting, ect.
                Gordon
                  Well, I did it a little different
                  I took my Dremel and cut a slice out of the spacer as shown below, filed it smooth and slid it around the stud with the open section facing down. Let down the trans and torqued the nut to spec. I figure with all that weight on it, it's not going to go anywhere
                  Thanks to all for your help!
                  Clark in San Diego
                    Clark in San Diego
                    "Necessity is the mother of invention." [8D]
                    <h5>Mark
                    '57 Transtar Deluxe
                    Vancouver Island
                    Are you planning to attend the NW Overdrive Tour in Parksville, BC
                    May 23 & 24, 2009?
                    </h5>
                    Mark Hayden
                    '66 Commander
                      This is the correct way to do this install. The mount has to be taken
                      off the bellhousing, that will give the room needed to lift the mount
                      high enough to put the spacer on, and back into the crossmember. This
                      is how I installed them back in the day. Good advice. Theres a chance
                      that the slotted washer COULD work its way out over time, this is why
                      Studebaker used a full washer/spacer. Good luck with your mod, but it
                      would be in your best interest to follow Tom B's advice when you have
                      more time to make it "right".
                      Tom
                      '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
                        I most likely will, since frankly it bugs me to have to do it like this. I have a spare original spacer (with the part number stamped in it!), but this at least gets me further down the path to getting the car running. When it's back on the road (and after the brakes have been gone through), I'll take it to my trans guy and let him bust his knuckles getting that mount off the bellhousing!
                        Clark in San Diego
