View Full Version : Stupid Question
61LaRk4dr
07-24-2008, 01:58 PM
Hello,
Excuse my ignorance, but in the repair manual for the AS model carter carburetor it describes screwing the idle screw into the carburetor body until it "bottoms out lightly" then it says to "rotate the idle screw outwards a full turn."
The question:
What the devil does "bottom out lightly" mean and is there a more accurate way of adjusting the idle screw?
Thank you
1947 Studebaker M-5
1948 Studebaker Land Cruiser
1961 Studebaker Lark 4-dr. Sedan
http://images1.filecloud.com/690439/untitled.JPG
Andy R.
07-24-2008, 02:03 PM
I would guess when you first detect contact with the lightest touch...
Andy
62 GT
http://a6.vox.com/6a00cdf7ec2443094f00e398c6501e0004-pi
Chucks Stude
07-24-2008, 02:18 PM
That method has worked well for years.
Skip Lackie
07-24-2008, 02:20 PM
They want you to screw it all the way in, but not so hard that you'll damage either the needle end of the screw or the seat in the carb body.
Skip Lackie
Washington DC
Chucks Stude
Forgot to say, that after you get it running, fine tune the idle with a dwell tach or whatever you have to do that with.
DEEPNHOCK
07-24-2008, 03:12 PM
That is a good point to reiterate...
Set the points (dwell) first.
Set the timing second.
Set the carb idle mixture screws third.
Set the idle speed screw fourth.
07-24-2008, 06:21 PM
I might add (once again) that the only Stupid Question is the one not asked.[:I]
1957 President two door
theGman
07-25-2008, 10:42 PM
I was waiting for someone to say that! : )
