This probably sounds like a simple question but I was wondering where to check the fluid level on the transmission. Also what fluid to use in it. Thanks
auto transmission in 51 studebaker
The dipstick should be under a cover on the passenger side of the transmission tunnel.
Use Dexron fluid.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
My 55 has the inspection port on the driver's side of the transmission tunnel. The transmissions from 51 on, maybe to 56 were all Detroit Gear, might all have the same inspection ports.
[img=left]http://www.alink.com/personal/tbredehoft/Avatar.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
(Under Construction) 363 hrs.
'05 Legacy Ltd Wagon
All Indiana built cars
Paul Johnson, Wild and Wonderful West Virginia
Museum R-4 engine
1962 Gravely Model L (Studebaker-Packard serial plate)
1972 Gravely Model 430 (Studebaker name plate, Studebaker Onan engine)Paul Johnson, Wild and Wonderful West Virginia.
I don't know how long it continued to be recommended, but the first DG trannies in 1950 called for 10W motor oil as the transmission fluid.
Museum R-4 engine
quote:the first DG trannies in 1950 called for 10W motor oil as the transmission fluid.Brad Johnson,
'56 Sky Hawk in process
Wouldn't necessarily need to. Chances are it's already been supplanted at some point.
It is a good idea and, I believe, recommended maintenance to drain all fluid and clean or replace the filter screen every 50,000. If you don't know when it was last done, what's the harm in doing it now?
One nice thing about the DG200 torque converter is it has its own drain plug. What an archaic idea!
Brad Johnson
'33 Rockne 10, '51 Commander Starlight, '53 Commander StarlightBrad Johnson,
I would not chance it. Drain the 10W out, even the convertor. The ATF has friction modifiers in it to work with the clutches and bands. The motor oil does not. It's not good to mix. Not long after that tranny was out in the publics use, IIRC, dealers were notified to change the oil to Type A ATF. Type A has been upgraded through the years. Now Dexron is reccomended. Again, IIRC, that tranny oil level is checked at normal operating temp. and gear selector in Low. Make sure the emergency brake is applied and wheel(s) are chocked. Hope this helps.
Dan Miller
Auburn, GA
The Studebaker Automatic Drive manual says to check the fluid fully warmed up and with the transmission in L. It stresses to not overfill. It also tells you to check the fluid every 1000 miles and drain and refill every 15,000 miles. For a new car in normal use, that was about one year. On Studebakers with the DG transmission, I always changed the AT fluid every year. Fluid is a lot cheaper than transmissions. For a COMPLETE change, start with five quarts, start the engine (AT in L) and add three quarts. When fully warmed up, add fluid to bring up to Full mark (do not overfill).
Studebaker enthusiast much longerGary L.
I'm experiencing what appears to be a major Transmission leak, but cannot find source. Is it possible I overfilled it? I tried to drain everything, but who knows? I put in 4 or 5 qts before starting then 6 or 5 quarts after it had run a while. Now, it has lost somewhere over a pint in my 'catch pan,' never mind whats on the road. (six miles)
Tom Bredehoft
'53 Commander Coupe
(Under Construction) 366 hrs.
If I drain the torque converter will it just refill when I fill the tranny and start it? I was always taught to fill the torque converter when I installed it and the fill and start the vehicle. Never had a drain on the convereter before. Thanks
Tom Bredehoft
The way that I read your post, you put in nine to 11 quarts. This is too much. Drain it down until it as at the full mark with the transmission warm and in Low. Studebaker emphasized not overfilling these transmissions.
