Seeing as how Skip Lackie has done a great job of updating/correcting the V/8 engine ID data on our Tech Tips, Specs & Data page (see the topic in the General Discussion Forum) I decided to give an engine I acquired quite a while ago a closer look. What I saw has me confused to what I have so I come to you.
Where the number is supposed to be stamped at the right front it looks like this:
Back at the left rear it's stamped with this:
It has dished pistons marked L-2027 STD (I presume standard size):
The heads are 527772, which, if the data is correct, makes it a 7.0:1 c.r. (51-54 with the small valves?)
At one time prior to my acquistition it supposedly had a VS57 supercharger on it.
Is this a 224 or 232 or what? I picked this up ($50 bucks, including 4-bbl intake with wcfb) thinking it would go in my 49 2R5 project. If it is an early V/8 I'm not so sure I want to use it...or should I?
BShaw,Webmaster
webmaster@studebakerdriversclub.com
60 Hawk. 49 2R5, 39 Champion
Woodbury, Minnesota
BShaw,Webmaster
Woodbury, Minnesota
