View Full Version : ELECTRONIC IGNITION Systems for Studebakers
Champion51
07-20-2008, 12:18 AM
Was just curious as to why there have been no posts,(tried search),or no entries on 'tech tips,specs' on electronic ignition systems. I am not knowledgeable with the ignition systems on cars. I imagine there are hundreds of other members in a similar predicament.
Conversions from 'points' to electronic ignition is apparently simple but can be complicated by many factors as dictated by the year,model,make,eng.size etc. I have checked out many web pages but have found nothing specific to the 259 in my '59 Hawk. I have talked to dealers like Bill C. on the phone but am still as confused as before.
I sure would like to see, a methodically, easily understood paper on the logistics of installing a "P." or "C." ignition system.
As the popularity of the newer technology increases, I think members need to understand
1)the benefits and/or drawbacks of E.I.,
2)the basic installation procedure,
3)the complicating factors in the various Studebaker engines such as the Ohm factor, flamethrower coil required, using the original coil, problem shooting, etc.,etc.
4)the [u]do's and do not's</u>, as they pertain to what to purchase, how to install.
I do want to convert over but need some help. Anyone done a conversion on a '59, 259 Hawk?
If there are others in the same boat, please "second" this query in a short reply (the 8-ball smiley would do) and maybe something will happen? I think it would be an excellent addition to the "tech tips" on our forum! Many thanks to the individual(s) that could accomplish this challenge.
Dave D.
'51 "Bulletnose" Champ
'59 "Silver Hawk V8"
Smithers, B.C.
52 Ragtop
07-20-2008, 12:24 AM
I used the Pertronix for my 52 commander 6v pos grnd. with a 289 stude and a flight o matic. Starts better, and seens to be good onthe road, I do need to "play" with the metering rods and jets. Carb is a 500 cfm carter/edlebrock
Jim
Warren Webb
07-20-2008, 01:22 AM
I have used the Pertronix system on my R-2 Hawk, 60 Lark & 61 Champ with satisfying results. Being the Champ & the Lark both had a delco distributor made it real easy & the R-2 had a dual point that was available with a Pertronix.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
07-20-2008, 02:37 AM
Dave; no offense intended, BUT I think you are over thinking this! :) You buy a early Delco (same '56-'60 Hawk) Pertronix Igniter system #1187LS from a Stude. Parts Vendor, take out the points and Condensor and drop in the Pertronix module in their place, connect 2 wires to coil per the instructions and forget you have a distributor! [^]
I did it to my '59 Lark (same Dist.) and I have no electronic knowledge, nor did I need any! [:0] Runs great!
The instructions did say NOT to mess with the resistance wire or resistor block, UNLESS you buy their High Output Flame thrower 40,000 Volt or 45,000 volt Coil which has a built-in resistance, so does not require a external resistor. So if you have a Pink resistance wire, you disconnect it and add a copper wire from the Coil to the Ign. Switch.
There are trouble shooting instructions included if you make a mistake, otherwise none are needed and no downsides except, like all factory systems the module (pick-up) could eventually fail, you throw it away and install your spare, same as points. [:0]
PlainBrownR2
07-20-2008, 03:24 AM
For me there was really nothing to the Pertronix ignition system. Just pop the cap, pull the plate and points, install the module to plate, reinstall, drop magneto(I think thats it) on shaft, and wire using the diagram inside of the box. I did one to a dual point Prestolite a coupla years ago for a 64 Lark and an Autolite 6V positive ground for a 50 pickup with the Champion six this spring. I also sprung for the Flamethrower coils for both and haven't really had a trouble with either yet.
One thing about the Autolite though. It had a post that affixed the points, and adjustable spring , and arm. It was an adjustment mechanism to help easier set the point gap, and unfortunately, had to go. Fortunately the Pertronix was a set and forget system in this case, but if it goes, it will need a spare(but widely available) new distributor plate along with the points.
http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000145-1.jpg[img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000137-1.jpg[/img=left][img=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/DSC00005.jpg?t=1171153370[/img=right]
DEEPNHOCK
07-20-2008, 10:09 AM
There are plenty of threads on this subject..
Just put the word Pertronix in the search box and hit enter...
You'll find some good reading on the subject.
http://i77.photobucket.com/albums/j54/deepnhock/aaaImage1.jpg
Dave D.
Smithers, B.C.
Mark57
07-20-2008, 11:16 AM
Rich - I should have asked you while down in Oregon City last week, but what are the 1187LS's selling for these days?
<h5>Mark
'57 Transtar Deluxe
Vancouver Island
Are you planning to attend the NW Overdrive Tour in Parksville, BC
May 23-25, 2009?</h5>
http://i186.photobucket.com/albums/x153/MarkH57/DSC00200C.jpg
Mike Van Veghten
07-20-2008, 12:23 PM
For what it's worth, I do believe MSD, Crane and Mallory...also make drop in modules for the Delco distributor.
And all are just that, take the points-condensor out, install the module (and or ring) connect the wires to the coil, close the hood.
While it can be done in the car, it's much easier to clean things up a bit and do the install on the work bench.
Champion51
07-20-2008, 12:28 PM
OK, guys. Thanks for the info. Didn't do the right search in the first place. Lots of good stuff found under a 'Pertronix' search. Even printed off the install procedures. Thanks again!
Dave D.
Smithers, B.C.
Champion51
07-20-2008, 01:05 PM
Mark - Pertronix lists a IGNITOR DELCO EARLY 8cyl., 12V Neg grnd. for $100.79. The Black 40,000 V flamethrower is $31.89. It is the 1.5 Ohm which I think is suitable for my application. Don't think I really need it.
Dave D.
Smithers, B.C.
07-20-2008, 03:04 PM
Mark, with your Forum Discount, Regular Customer Discount and Good Guy Discount the FOB Ferndale, WA price is in the email I sent, but let me know if you do not receive it, lately some forum sent emails go to Spam or do not work! [:0]
Ferndale, WA
Mark57
07-20-2008, 03:32 PM
Ferndale, WA
Thanks Rich - e-mail received & reply sent.
<h5>Mark
'57 Transtar Deluxe
Vancouver Island
BrianC
08-09-2008, 09:16 PM
I have a 63 GT Hawk with what appears to be a Autolite distrubitor with vacuum advance (no id plate). My problem is that i can't seem to get a Pertronix conversion for it. However, Pertronix does have one listed for the 57 Packard with a 283 v8, would this be the same creature?? Does anyone know of a conversion unit that i can use. Thanks, BrianC
farmhawk
08-09-2008, 11:38 PM
A word of caution when using the Pertronix unit when trouble shooting electrical issues, do not leave the key in the start position for very long, less than a minute, you will fry the unit. If you are doing lengthy diagnosis, disconnect the unit's wires from the coil. You will still have power to everything but the distributor. A replacement unit runs about $8.00 less then the complete setup. This is experience talking.
Wayen K.
Libby, MT
61 Hawk (On the road, FINALLY)
dong
08-09-2008, 11:53 PM
I found an Accell Ignition module at Advance auto that is supposed to be for the Stude V8 with Autolight distributor. The part number is 1584. I don't know if that is the Accell no. or the Advance no. or both. I have not bought the unit yet so can't give you any info on operation.
Don
BrianC
08-10-2008, 08:28 AM
Hello Don, I have purchased the 1584, it's a Pertronix unit for Prestolite distributor, it doesn't fit the Autolite. See my problem!! Pertronix has a unit for a distributor without vacum advance. i can't see what difference that would make and wonder if it will work. I've e-mailed Pertronix, sent them pics of the unit, no reply. I guess they're not big on customer service. Thanks anyway.
BrianC
Nl.
dong
08-10-2008, 12:12 PM
Thanks Brian, you saved me some aggravation as I was going to go down and buy it.
Don
wayne
08-10-2008, 07:16 PM
I had a question about Petronix and I E-mailed them and they where very helpfull. I ha a 6 volt commander with overdrive an I wanted to know how to install a resistor on the the kick down switch and it has worked great. I would try to contact them again.
BrianC
08-12-2008, 06:58 PM
Don, Pertronix doesn't have a unit for the Autolite, they said that they are working on it and may be available next year. However, Crane Cam has a unit 700-0231 or unit 700-0232 with an external control box that you mount on the firewall. I have heard from Canadian Studebaker that it works and i ordered the 0231 unit. I should have it in a week or so and i'll keep you posted if it fires up ok.
BrianC
NL.
dong
08-12-2008, 09:55 PM
Thanks Brian, I'll look for it.
PS. does the NL in your signature stand for Newfoundland?
Don
PlainBrownR2
08-12-2008, 10:14 PM
Now this is the Autolite for the V8 I presume? Pertronix has a kit for the Autolite IAT 4001 which is for the 170 positive 6V flathead six. That number is Pertronix 1569P6, however there is a catch. That Autolite requires a removal of the post and hardware as the dist had an auto adjust feature on the points with a simple twist of the screw. That is all removed when it is installed.
BrianC
08-13-2008, 08:01 AM
Yes by!! Newfoundland, the Rock. I'm in St. John's.
Andy R.
08-13-2008, 04:40 PM
FWIW, the Crane system I installed in my '63 Daytona Wagonaire years ago was a waste of money and a disaster, leaving me temporarily stranded thrice in as many weeks. I followed the installation instructions to the letter and could not match the reliability of some well-adjusted points.
Andy
62 GT
http://a6.vox.com/6a00cdf7ec2443094f00e398c6501e0004-pi
BrianC
08-13-2008, 09:27 PM
Hey Andy: Are you still running points in your GT? Does your GT or Daytona have Autolite distributor? I'm not having any problems with the points set-up in my 63 GT, however,performance is marginal and i've heard so much about how much better the conversion is and what a big difference it makes. Most say it's like a whole different performance level, an absolute must have. Maybe there's a signifigant difference in PERTRONIX and CRANE????????
Andy R.
08-14-2008, 05:08 PM
Maybe I'm just lucky. I'm still running the bone-stock distributor/points setup in both GTs. Both work well enough that I can't even remember which distributors I have.[:I]
They both purr like kittens and settle into a smooth, even tone at 900+ rpm and pull San Francisco hills without drama.
The performance increase from the Crane system was imperceptable to me. Fine-tuning the carburetion and replacing the centrifugal advance springs had a much more noticeable effect on performance.
Far be it for me to knock (no pun intended) anyone's electronic ignition system. There are surely more capable mechanics here than I. It just didn't work out for me. :)
Andy
62 GT
Mr Mike
08-15-2008, 06:14 AM
I have the 1183 kit in my 60 Hawk with a no-window Delco. What's the difference between it and the 1187LS kit?
Mr Mike
roy fraley
12-26-2016, 10:12 PM
I'm also interested in mallory electronic distributor for my 63 Champ 289
bensherb
12-26-2016, 11:30 PM
I have a GM HEI electronic distributor in my GT, it works great. I had heard of the problem of burning out the pertronix unit if the key is left on without running the engine, and it just seemed to be far too fragile to me. So I decided the factory GM unit would be the better choice. I've been running one in my '73 Ford "FE" 390 for 28 years and have never had to take a second look at it.
60802 60803
The HEI distributor head is larger in diameter than the Delco window one I replaced but it still clears the firewall of the GT ok, earlier cars might need some clearancing. I also repositioned my PCV. Where it mounts at the rear of the carb/valley pan may have worked but I thought it would be awfully close to the distributor so I used a couple brass fittings to lay the PVC down and give more clearance. I have an old Accel super coil on mine, (mainly because I like the cover) but standard HEI coils are comparable in output to it these days. I have a 3 speed overdrive trans, I still haven't completely determined how to properly operate the kick down with this distributor. I have determined how to drop a few ignition pulses but as yet have not been able to get confirmation that it will not affect the ignition module. Since I have never hit the kickdown switch without doing it intentionally to be sure it worked, I currently have simply adjusted it outside of operating limits. You don't want to cut power to the holding coil of the solenoid without cutting the ignition; the locking pawl will remain engaged until drivetrain load is sufficiently reduced, then not release smoothly. The result is unsettling at best, and could be damaging to the trans.
This distributor should work in any of the V8's but is designed to be used on a 12 volt negative ground system. If anyone is interested in one I can make more, as time permits, but a distributor gear and oil pump drive shaft, or core distributor, would be required.
07-04-2017, 03:51 AM
Mr Mike
I would be amazed if your Early Delco equipped '60 Hawk even RUNS with a '56 Packard Dual Point Autolite Distributor Pertronix Unit! :ohmy: :eek:
THIS is why it is important to buy your Pertronix Unit from a Studebaker Vendor like Phil Harris at Fairborn Studebaker who KNOWS what you need.
On line Parts Vendors and even Pertronix Co. do not know which unit is correct. :mad:
rkapteyn
07-04-2017, 09:02 AM
Buy Dave Thibeault's units.
http://www.studebaker-info.org/Vendors/tbow/tbow0513b.html
alpayed
07-04-2017, 07:25 PM
You could use a Mopar conversion
http://www.studebaker-info.org/Tech/Atyler/atylerHEI.pdf
Allan
(http://www.studebaker-info.org/Tech/Atyler/atylerHEI.pdf)
