View Full Version : 1955 224" V8 pistons needed
11-02-2006, 09:13 PM
Greetings, All,
Am rebuilding the 224" V8 from my 1955 3/4t pickup. Any leads on 224" oversize pistons will be appreciated.
thnx, jv.
11-02-2006, 10:00 PM
Sorry, they are no longer available, just put in a 259 crank and new 259 + .020 or .030 oversize pistons and bore it to match, you can re-use everything else that is in good shape. Any size 224 piston is like hens teeth to find nowdays, & when you do, they are old leftover "STD" size that no one can use anymore.
Studebakers Northwest
Ferndale, WA
rockne10
11-02-2006, 10:35 PM
If 224 is a must have, you could inquire here:
http://www.egge.com/inquiry.asp
Brad Johnson
33 Rockne 10
51 Commander Starlight
53 Commander Starlight
http://i57.photobucket.com/albums/g233/rockne10/51x2.jpg
11-02-2006, 11:12 PM
I scored a set of .040 over 224 slugs off ebay about a year ago. I watched them go thru the auction cycle without getting a bid at $150, then wrote the seller to ask if they could be had for less. Got them for $125.:D THEN SASCO ran an NOS 224 crank for 49.95 starting bid and that's what I won it for![^]
Miscreant adrift in
the BerStuda Triangle!!
11-03-2006, 11:53 PM
FWIW, I have used Egge Machine pistons in Packard V8s. They might be OK for a trailer queen show car which is only started to go on and off the trailer, but they are not suitable to a driver. They have to be fitted with at least .0035"-.004" clearance or they will run hot and scuff. Instead of Egge pistons, I will sleeve a block back to standard and re-use the old OEM pistons again.
PaulDriver
11-05-2006, 04:01 PM
Have you asked Maddog Racing and Fastengineparts? Their studebaker parts can be found at
http://search.stores.ebay.com/Maddog-Racing-and-Fastengineparts_studebaker_W0QQfciZ15QQfclZ3QQfsnZMaddogQ20RacingQ20andQ20Fasten ginepartsQQfsooZ2QQfsopZ3QQftsZ2QQsaselZ29841065QQsofpZ0?
and more specifically, their 224 pistons are located at
http://cgi.ebay.com/ebaymotors/Studebaker-224-1955-V-8-pistons-new-set_W0QQcmdZViewItemQQcategoryZ33623QQihZ019QQitemZ7960322391
11-05-2006, 06:26 PM
FWIW, Maddog Racing and Fastengineparts is just an ebay reseller. He re-sells Egge Machine pistons and has nothing which is not available elsewhere at a lower cost.
