53 54 grills / 2dr. vs. 4dr.
  • 53 54 grills / 2dr. vs. 4dr.
    Can any one tell me if a grill and related parts from a 1953 4 door will fit on a 1953 2 door? I also wonder about the hood.
    Thank you very much
    Chris
    4 door front is same as 2 Door SEDAN or (1954 only) 2 Door WAGON.
    Not the same for 2 door coupe (C body) or hardtop (K body). These are lower and flatter front ends.
    Dan
    52 hardtop
      I think the only part that interchanges on those front ends with the coupes or hardtops are the grill bars, not the grill surrounds. Someone will correct me if I am mistaken.
      sals54
      sals54
        Chris, There were 2dr sedans and 4dr sedans and both use the same grille pieces.
        There were also coupes and hardtops and they both shared grill pieces. But The coupe-hardtop pieces and the 2dr-4dr sedan pieces don't interchange SAVE FOR the center bars that have the parking lite incorporated. For 53 only, these bars fit any of the Stude models.
        For 1954 - NONE of the pieces interchange between sedans and coupe-hardtops.
        1957 President two door
          Dan
          52 hardtop
            Thanks so much for all the help.
            I have had a 55 hard top in my garage for about 15 yrs.and would like it to look like a 53/54.
            Are there any reproduction parts out there?
            Again thanks alot.
            chris
              I happen to like the looks of the big Sabre-like grille.
              However, many get painted because of rechroming costs, and some prefer the look. (Just the centre bar chromed.)
              Apparently, the grills were originally going to be painted accoding to the designers, but the sales guys wanted more chrome to compete with Buick.
              Your car, your choice, but 53-54 coupe and ht grills are pretty scarce. They will be expensive.
              Paul
                Those parts are a budget buster for any restoration, over 2K for show grills.
                JDP/Maryland
                "I'm a great believer in luck and I find the harder I work, the more I have of it."
                Thomas Jefferson
                JDP Maryland
                  quote:would like it to look like a 53/54.
                  Then you're going to need more than the very expensive grills; hood, air deflecters, etc, etc.
                  It's not undoable and, someone would probably love to have your orphaned grill, parking light housings, hood, etc.
                  I believe hoods are being repopped in fibreglass and good steel hoods can still be found at swap meets.
                  Restoring your '55 as is, would be a much less daunting task.
                  Brad Johnson,
                  '56 Sky Hawk in process
                    These guys make fiberglass '53/'54 front ends :
                      Last I heard Dave Theibeault (T-bow) was still reproducing the surrounds in brass, $200 each you finish (unchromed). Not a bad deal considering you can spend some time final finishing before turning over to the chrome shop. The bars are a little easier(cheaper)to find since they do interchange between coupes and sedans.
                      Steve Hudson
                      The Dalles, Oregon
                      1949 "GMOBaker" 1-T Dually (workhorse)
                      1953 Commander Convertible (show & go)
                      1953 Champion Starliner (custom/rod project)
                      1954 Champion Coupe (daily driver)
                      1960 Hawk (future project?)
                      Steve Hudson
                      The Dalles, Oregon
                      1949 \"GMOBaker\" 1-T Dually (workhorse)
                      1953 "Studacudallac" (project)
                        I'm also planning to 53erize my 55 since my first car was a 53 commander. I've picked up a donor 54 champ coupe thats beyond saving and a 53 commander dash so I think I have most of the necessary parts. I'm going to leave all the 55 greenhouse stainless on it, so it won't fool too many people. I'd like to get a pair of reproduction grille surrounds if someone could provide contact info. I heard that some one also was reproducing tail light housings at one time, are they available? Thanks
                          I believe that Dave T. has a business card size ad in the back of every Turning Wheels. He is the guy with the reproduction C/K grille shells. It should be safe to assume that you are a member of SDC. If not, join for only $19.95 from this web site.
                            I've had both the fiberglass and the brass aftermarket shells, and would suggest sticking with fiberglass unless someone really has to have metal/chrome. There's some great chrome paint available out there that really looks the part and would work well on the fiberglass with careful masking/prep. Unfortunately, the brass shells are ridiculously heavy and require tons of prep work -and chrome plating costs $$$$$$ these days
                              Will,
                              Are you saying someone is repopping the grills in fiberglass?
                              Brad Johnson,
