I took the 52 out for an hour's drive and upon my return I lifted the hood and found a slight splashing of oil on the firewall and underside of hood near the firewall, on the driver's side. I put oil in the car the day before. I didn't fill it up. I checked around the filter and oil filler cap. Both had a slight film of oil. Any thoughts as to where the problem lies? Thank you.
Oil blow by
I'm having the same problem with my 53 coupe. It's only been bad (oil all over hood and firewall) since I put in a 6 blade fan. Sometimes there's no oil at all, other times it's terrible. I've verified that the draft tube is not blocked, I've reduced the oil flow to the fuel pump and filter down to .035 orifices. This helps my oil pressure, but not the 'decorations' on the hood.
[img=left]http://www.alink.com/personal/tbredehoft/Avatar.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
(Under Construction) 353 hrs.
'05 Legacy Ltd Wagon
All Indiana built cars
The oil on the hood starts just behind the oil fill stand, a long way for'd of the flex line.
Tom Bredehoft
'53 Commander Coupe
