View Full Version : NAPA gaskets
dclewallen
11-01-2006, 04:47 PM
Awhile back someone recommended a part # for some Studebaker V8 exhaust gaskets from NAPA. I did a search but was unsucessful. Anyone know the part #? Thanks again,
Darryl C. Lewallen Clarkesville, Ga.
sbca96
11-01-2006, 05:04 PM
Napa manifold exhaust gasket is: F5436 Ak. Made by Dana. Its a thick
composite mesh with inner fire steel ring.
Tom
dclewallen
11-01-2006, 06:03 PM
Tom, Thank you for part number, I'll get these tommorrow.
am not r2
11-01-2006, 10:24 PM
I got some of these last week, I matched them up to a manifold that i HAD from last year. (snaped the stud off.) It has motivated me to try out die grinding, I want to scribe the fire ring circle then grind to that. I am trying not to ruin the ones on my car on my first attempt/
R
64 Daytona HT
11-02-2006, 05:33 AM
Are these manifold to pipe, or manifold to head? I'd be interested in opening up the pipe end of the manifold. Are right side pipes available to fit well without the heat riser.
Mike M.
am not r2
11-02-2006, 06:32 AM
man to pipe. the guy from canada that advertises in TW. will do them I think. My car came with these pipes and no heat riser valve.[8D] I wanted to make the most of them. this seems to be the bottleneck in my system.R
64 Daytona HT
