View Full Version : Timing by vacuum
07-09-2008, 06:31 PM
In the recent Auto Restorer, Milt Webb is tuning up a Rambler and suggests the timing adjustment by gently rotating the dist. in the opposite direction of it's travel...I would twist clockwise in the case of my OHV Stude 6...while it's running with a vacuum gauge plugged in. As you rotate the dist, watch the vacuum climb and when the engine begins to stumble from being too advanced, bring it back to within an inch from the highest reading.
Sound kosher? Thanks in advance...or retard in my case! [:p]
Western Washington, USA
07-09-2008, 06:38 PM
I advance my 259 dist. until I get the highest vacuum reading--it seems to run best there and does not kick back while starting. I plug the vacuum advance and PCV valve before setting it.
Mike Van Veghten
07-10-2008, 09:11 AM
It works if you have a "non"-dampened vacuum gauge.
A dampened gauge just isn't sensitive enough to do that correctly.
