View Full Version : 289 carb.
richnan
10-30-2006, 06:07 PM
Hi
Have a 57 silver hawk with a 1962 289.. It has a 4 barrel.. I have had some flooding problems with it from time to time.. Wonder what would be a good replacement for the carb.. something that would just bolt on with not too much adjustment..
Thanks Dick
silver hawk
http://thumb15.webshots.com/t/55/155/1/78/69/2455178690029093115TDRPdQ_th.jpg
64V-K7
10-30-2006, 06:35 PM
Edelbrock 1403 and a Mr. Gasket #97 spacer... a bit more fuel line... Hook the electric choke to the spare OD kickdown wire on the harness. Your throttle linkage can be easily adapted to the carb..
CHAMP
10-30-2006, 06:38 PM
If it were mine I would rebuid the carb. Or have someone rebuild it for me.
10-31-2006, 06:36 PM
Second the motion to keep the OEM carb. It costs about $300 and up to buy the new Edelbrock carb, spacer, gaskets, fiddle the linkage and the choke. For a little more, the best in the business, Daytona Carb, for one, will make yours like new. It will fit, it will work perfectly, be stock and and it will last another fifty years.
John Kirchhoff
10-31-2006, 08:49 PM
Mine leaked too until I rebuilt it this summer. I got a gasket kit from NAPA for either $32 or $35, can't remember which and they had it the next day. Easy to follow instructions included float levels for Studebakers. Unless the throttle shaft bushings are completely wallowed out, a gasket kit, an old toothbrush and a can of carburator cleaner should get it fixed up. The toothbrush works more effeciently if you warm the handle up over a fire and bend it into an "L" shape
