Hello Group,
I'm in a bit of a quandary. Our automatic drive shop manual has instructions for adjusting the accelerator-to-carburetor linkage, but it doesn't cover 5H (1954) models. While some would automatically say that the adjustment is the same as 4H 1953 models, there was a bit of a difference between the carb linkages for those years. Take a look at the attached image; particularly, look at Fig. 68. Specifically, 1954 model carburetors did not have the adjustable rod on the carb end of the throttle linkage. The spring from the cross shaft arm was simply attached to the carb bellcrank. So what is the correct procedure for adjusting this linkage?
I need to make this adjustment before I adjust the accelerator-to-governor linkage.
Kindest regards,
Alan Mende
Hummelstown, PA
Kindest regards,
Alan Mende
Hummelstown, PA
