View Full Version : '56Power Hawk defrost motor
John Ratliff
10-28-2006, 12:45 AM
Have anyone come across the wire going into the defrost motor being bear of insulation. The insulation has disintegrated. Any ideas as to replacing the wire? I know that motor can not be easy to remove.[xx(] HELP. Have thought about trying heat shrink on the wire.
60Lark
10-28-2006, 01:35 AM
John, I had the same situation with my 51 Champion, I removed the defrost blower assembly, disassembled it, took the motor apart and soldered new motor leads, while it was apart I oiled the bearing wicks, and cleaned the mtor stator, prior to reassembling it, the motor now runs smoothly with no fear of shorting out. It wasn't that big of job to get the defrost assembly out, I removed the glove box door and liner which make it much more accessible, then removed the nuts from the mounting studs inside the engine compartment, removed the defrost hoses and pulled the assembly out from under the dash. I am not particularly familier with the 56 Hawk, but I can't imagine it being a whole lot different. The heat shrink might work, but I don't recommend it. Just my opinion.
http://im1.shutterfly.com/procserv/47b6ce23b3127cce8d0f1fc7bd4900000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
John Ratliff
11-03-2006, 10:57 PM
Thanks Phil. I got the defroster unit out and took the motor apart. Wired in new wires cleaned the stator and lubed the bushings. Got it back in today and found the switch only worked on slow. So I pulled the switch and spayed contact cleaned in it and let it set about an hour. Worked the toggle a few times then put it back in. Every thing works great. No smoke!:D I also cleaned out the defrost hoses with a bottle brush. It did a good job.;) Thanks again. John
60Lark
11-04-2006, 12:13 AM
John - Sounds good, I'm glad it worked out [^]
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
bams50
11-04-2006, 05:21 AM
What's all this about defrosters?!? Since when should Studebakers ever see frost?!? ;)
Parish, central NY 13131
N8N
11-04-2006, 06:33 AM
just an idea for "next time" - if the motor works OK why not just slide some heat shrink tubing over the bare wire and letting it go. like you say R&Ring it IS a PITA. Of course if you don't R&R it that almost guarantees that one of the bushings will seize up soon. :) Ilike to put a little synthetic grease in the bushings just in case (since you can't get at them)
60Lark
11-04-2006, 11:41 AM
Nate, IMHO if the wires have been around long enough for the cloth covering to deteriorate into dust, the motor and bearing also need attention, I agree that heat shrink is OK for a short term fix but only for short term. I also agree with the synthetic lubricant, I actually use a liquid synthetic lube, in lieu of a grease.
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
11-04-2006, 01:35 PM
What I've done on some motors I couldn't get apart (sometimes those with the squirrel-cage fans DO NOT want to come off without practically destroying them!)is to use a wire-sized drill in a dremel tool and drill a small hole in the case's dome where the end bearing/bushing is and then squirt some 3-in-1 or some such in there to lobe that bushing. The other end, you can usually get some oil onto the bronze oilite bushing using one of those extendable spout oiler bottles.
I have several of those bottles of swamp cooler oil around here. It's GOOD all-purpose oil and the 6" extendable spout is super handy for oiling places that would otherwise be a pain to lube.;)
Miscreant adrift in
the BerStuda Triangle!!
http://i102.photobucket.com/albums/m111/studebob/Trstrsside.jpg
